My 2007 Silverado Build...again
Old Nov 10, 2010 | 02:41 PM
  #131
Phantom's Avatar
11 Second Club
In case someone doesn't care to look at all my pictures and put 2 and 2 together...Changes are:
799/243 heads milled .030
Lunati .660 lift dual springs
GM .055 MLS head gaskets (lost a little compression, should be around 10.2:1 now)
GM LS7 lifters
GM header studs
GM header gaskets
New COMP pushrods
Pat G custom cam
I've also purchased some
Summit Racing 50/50 rear drag shocks
Summit Racing 90/10 fronts
Not the best option I know, but definitely better than what I have now and relatively inexpensive as well.
I ALSO recently put a Nitrous Outlet plate on my truck and redid my nitrous wiring. I'll snap some pics after the truck is put back together and cleaned up.
Old Nov 10, 2010 | 04:14 PM
  #132
DV2000NJ's Avatar
13 Second Truck Club
Sounds like a good plan. What are the specs on the cam?
Old Nov 10, 2010 | 04:18 PM
  #133
Phantom's Avatar
11 Second Club
Oooohhhh...about that...
Old Nov 10, 2010 | 04:21 PM
  #134
DV2000NJ's Avatar
Ish?
Old Nov 10, 2010 | 04:22 PM
  #135
Phantom's Avatar
11 Second Club
It's for nitrous...ish
Old Nov 10, 2010 | 04:31 PM
  #136
Tootall's Avatar
Gettin closer. Heads assembled, and coated, new gaskets and header studs
Still waiting on the new cam and then everything will be put together. Also going to paint my pieces that I have painted Bahama Blue now, Black.
did you paint the heads with the old exhaust gaskets still on there . . . ?
Old Nov 10, 2010 | 04:32 PM
  #137
Phantom's Avatar
11 Second Club
No??? Why?
Old Nov 10, 2010 | 09:05 PM
  #138
Tootall's Avatar
No??? Why?
I guess that I'm seeing the rough cast flashing on there . . .
kinda looks like the pattern for the exhaust gaskets on the sealing surface
Old Nov 15, 2010 | 01:00 PM
  #139
Phantom's Avatar
11 Second Club
Cam will FINALLY be here tomorrow...Also spoke with Chris @ Circle D this morning
Old Nov 15, 2010 | 03:58 PM
  #140
KozzyJr's Avatar
i noticed you milled the 243s, what length of pushrod are u running now?
