LVL 4 FLT 80e Swap into an '04 SSS
#181
#182
Also, was just wondering if any of you guys have the Transgo Shift Kit on your 80e's? I was thinking that maybe this would help and especially help with the super smooth shifting (which I totally can't stand).
#183
On a decently built trans, a transgo kit is pretty much pointless. The right combination of Sonnax valves and springs is better any day of the week IMO. On a stock build then a transgo is great. You can adjust shift pressures in your tune. There are other ways to adjust the shift but that would require some valvebody work and I wouldnt suggest that if you dont know what you are doing.
#184
#186
I am not saying there is anything wrong with a transgo it's just that all said and done if the trans is built there isn't much from the kit you will actually use unless it's a stock trans.
#187
Ya, I read you. I just watched the video again of you racing the S10, the trans sounds perfect to me? You want my opinion? leave the trans alone! And just for the record, I DO NOT use the Transgo kit in any of my 80's.
#188
My only concern is the downshift into 1st from a 40 roll - there is without a doubt an "issue" there and I'm hoping it's the converter loading up like Rob said in that earlier post.
#189
FYI, every built 80E I have driven in feels kinda odd on a hard 1st downshift. I thought mine was slipping under those circumstances also and logged it and found it was not.
Logging your trans input and output speed will tell you if it is. 1st gear ratio is 2.48 so break out a calculator.
#190
