LVL 4 FLT 80e Swap into an '04 SSS
Old Feb 28, 2014 | 05:13 PM
  #101
Mark Buck's Avatar
Default level 7 4L65E COST
Chuck, Just out of curiosity what would a level 7 FLT 4L65E cost built exactly like the one in your "test vehicle"?
Old Feb 28, 2014 | 07:09 PM
  #102
12secss e.mack's Avatar
yes, it is a tvs2300 jack shaft overdriven with a LC32 8 rib pulley system and 10% overdriven crank .
Old Mar 1, 2014 | 07:41 AM
  #103
L8ERBRO's Avatar
Bro, you'll go through some tires with that baby...very sweet! Do you know what's the max boost the Jackshaft can produce?
Old Mar 1, 2014 | 08:33 AM
  #104
L8ERBRO's Avatar
If you want to play, you got to pay!
Old Mar 1, 2014 | 09:54 AM
  #105
do not run a tvs2300 jackshaft sc overdriven with a 2.8 pulley or low you will over spin the tvs2300 and destroy it , I know trust me.....
Old Mar 1, 2014 | 10:02 AM
  #106
FLT's Avatar
FLT
FormerVendor
Here's the link to our level-7 build which is the same trans in Ed's truck, minus the gear set & trans brake options. The only piece he's missing currently is the new billet pump rotor, which I plan on installing this season.
Finish Line Transmissions | Performance Transmissions | Torque Converters | Transmission Parts | Transmission Service
Boy isn't that the truth!
Old Mar 1, 2014 | 03:42 PM
  #107
idahoblkss's Avatar
7k for a transmission ? let alone a 65e lol... ill stick with my $300 junk yard pull out 80e with a shift kit lol. also, who has the fastest silverado with a 2300? is there one even into the 10's? i thought those jack shafts break after a certain point?
Old Mar 1, 2014 | 04:33 PM
  #108
L8ERBRO's Avatar
I talked about this in my other build thread - There's no way in hell I would ever slap some POS junkyard trans. into my like new beauty...it just turned over 30k miles. If I had 150k on it, that would be another story, but to each his own I guess lol
Old Mar 1, 2014 | 04:58 PM
  #109
oakley6575's Avatar
What makes a junkyard trans a POS? Just the fact it was taken from a junkyard or what?
Old Mar 1, 2014 | 05:12 PM
  #110
idahoblkss's Avatar
you dont think the cores that flt or who ever the transmission builder is dont come from junkyard/salvage yard or a donor trucks ? the trans i got i pulled from a 2005 cc silverado for 350 bucks and came with a 4x4 transfer case . and then sold the transfer case for 250 and took the trans to my builder along with a shift kit where he torn the whole unit down , hot washed it , installed the shift kit after checking everything in the unit to make sure it was good he then painted it all for $200 so at the end of the day i paid 300 bucks plus 100 for shift kit and have a brand new trans that i have beat on for the last 4+ years on high boost. but like you said to each his own i guess.
