ls1 build for boost.shooting for mid 10s
Old Jul 3, 2011 | 11:23 PM
gavin2005's Avatar
Default ls1 build for boost.shooting for mid 10s
i've been throwing ideas around for awhile now and i finally decided im gone use the ls1.mods are gone be 1.vtc2 cam and prc dual springs 2.ported ls6 oil pump and ls2 hd timing chain 3.arp head studs and arp2000 rod bolts maybe forged pistons and 317 heads.still debating on that.my goal is mid 10s on 16psi
Old Jul 3, 2011 | 11:30 PM
pewterliftedz's Avatar
well blown06 went mid 10s with a 346 and a D1 procharger... its doable with boost and traction..
Old Jul 3, 2011 | 11:58 PM
gavin2005's Avatar
how much boost and was it a stock bottom end?
Old Jul 4, 2011 | 05:10 PM
slowlsx's Avatar
You can do it with stock bottom end but it definitely won't last long. Decent forged rods and pistons and a 76mm you can do it all day.
Old Jul 4, 2011 | 06:12 PM
gavin2005's Avatar
i have decided to go with forged pistons and scat rods.im trying to figure out which pistons and rods i need for stock bore
Old Jul 4, 2011 | 06:40 PM
gavin2005's Avatar
i think i found the pistons and rods im gonna use.mahle ls1314898f04 and scat 26125716.these is for 6.125 rod length.stock rod length is 6.098.with the longer rod,how is that gone affect me with boost?
Old Jul 4, 2011 | 10:33 PM
slowlsx's Avatar
Most rods are 6.125 and slot of people run them. I wouldn't go to low on compression either.
Old Jul 4, 2011 | 10:47 PM
gavin2005's Avatar
thanks.yeah im gone keep it at 10.1. and im gone run e85
Old Aug 18, 2011 | 12:30 AM
Blown06's Avatar
8 Second Truck Club
It was at 23 psi. Had Eagle rods and Mahle pistons.
Old Aug 18, 2011 | 02:55 AM
slowlsx's Avatar
that would be a great compression for e85! you should go mid 10's with about 15psi and a goood 60'
spiritfish
Aug 28, 2015 06:46 AM
USMCvet0311
Aug 14, 2015 10:28 PM
nrmskate
Aug 11, 2015 02:44 PM
fcompean
Jul 15, 2015 09:55 PM
Black-Syde
Jul 6, 2015 02:12 PM
