Jake's '05 Rcsb s488 4l80 build
Old Nov 2, 2016 | 08:06 AM
  #251
BigKID's Avatar
I presume that procedure/spec is for stock rods and bolts? ARP provides a different spec for their bolts on stock rods and aftermarket rods should have a procedure/spec provided by the rod manufacturer. However, IIRC, K1's specs for the degree method (as opposed to using a stretch gauge) were very similar to the one posted above.
Old Nov 29, 2016 | 07:14 AM
  #252
Jake75's Avatar
Any ideas on what bolt on exhaust i can get that will go on with little modifications? 4 inch dp stops under the passenger side. I want it to go out the back
Old Nov 29, 2016 | 08:52 AM
  #253
TrickTurbo's Avatar
Truck Sponsor
We have used mbrp with good success.
Had to modify the hangers for height.
And we added one at the of the cab for weight support.
Old Nov 29, 2016 | 10:06 AM
  #254
Jake75's Avatar
https://www.amazon.com/MBRP-S6004PLM...words=S6004PLM this one?
Old Nov 29, 2016 | 11:27 AM
  #255
JordanH's Avatar
Restricted
Something like that is going to be your best bet. I would suggest a nice 4" v-band for the bottom of the dp. Makes pulling the dp out for anything a lot easier! Hell, I would do a couple of them. One at the dp and another before the rear axle crossover.
Old Nov 29, 2016 | 11:34 AM
  #256
Jake75's Avatar
yea I'm wanting to put v bands on a muffler so i could pull it out and put a straight pipe in or use it like a cutout
Old Nov 30, 2016 | 07:07 PM
  #257
Jake75's Avatar
Here's a video of idle. Video is blurry on purpose lol not a potato recording
http://s20.photobucket.com/user/jpre...129_1.mp4.html
Old Dec 10, 2016 | 04:54 PM
  #258
Jake75's Avatar
Just got back from a week in Jamaica! It was badass now onto business!
The mbrp exhaust that I linked came in today and seems like it's going to fit. I just need to cut one piece and expand it so it can slide over the trick dp.
Old Dec 10, 2016 | 06:35 PM
  #259
TrickTurbo's Avatar
Truck Sponsor
Yep you can go to a big truck supply house. And pic up a transition.
I used a slip slip. Slip over down pipe. Slip over 4" pipe.
Or get slip to pipe size and weld into place.
Old Dec 10, 2016 | 08:01 PM
  #260
Jake75's Avatar
i like the slip to slip better! seems easier on me
