ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods
#311
Diggin this project!
I just read this entire thread between last night and this morning. Your work quality is absolutely outstanding! LIVE the Escalade console addition, that makes the interior VERY nice!
Really dig the turbo and all your work into cleaning up the engine bay.
I have a bright red RCSB also; mine's a 2011. This project is quite an inspiration!
#314
She is back to normal, can't even tell anything happened other than the lump under her neck skin where they put the pacemaker. Now we are prepping for her next surgery to remove a huge bladder stone... Also found out the girlfriends father has to have heart surgery in the next few weeks. When it rains it pours I guess.
Decided to tear apart the differential and tackle that job. Install kit shows up tomorrow, but still need to order the 3.90 gears
Install list is:
Trutrac
3.90 gears
Yukon axles
All new bearings
Main cap stud kit
Crush sleeve eliminator
TA girdle cover
1350 yoke
Install list is:
Trutrac
3.90 gears
Yukon axles
All new bearings
Main cap stud kit
TA girdle cover
1350 yoke
#316
Install list is:
Trutrac
3.90 gears
Yukon axles
All new bearings
Main cap stud kit
TA girdle cover
1350 yoke
Install list is:
Trutrac
3.90 gears
Yukon axles
All new bearings
Main cap stud kit
TA girdle cover
1350 yoke
#317
No, not crazy. I had built that a while ago but made some mistakes and had a slight whine and bearing noise. So I stripped all those parts out and going to redo it. Also, that axle wasn't prepped very well before paint, so it rusted and just looked like ****, the one in this truck is much nicer
#319
Sometimes I feel like its a curse, because I stress over dumb **** and redo stuff a lot if I'm not happy
Ordered the 3.90 gears at like 9pm Friday night, and they showed up Saturday morning. Summit is the ****
Pressed on the new bearings and then used the press to set the ring gear and torque the bolts down
Setup bearings on the pinion
Here's the final install pattern. 0.033" shim, 0.006" backlash, and 16in-lbs of pre-load on the pinion bearings.
Went for a drive after getting it all back together and I didn't hear a sound from the rear end. I could hear my tires on the road when next to a concrete barrier, so I know I should have heard a bad rear end sound.
I hope this one lasts and is quiet, my last install was full of whine and bearing noise, but I noticed that within the first 5mins of driving it.
#320
That pattern looks textbook perfect! Please report how you like the 3.90's. That's exactly what I plan to put in my 2011.
What is the diameter of your tires?
