ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods
Old 08-08-2018, 07:13 AM
  #311
Northeastconfederate's Avatar
Default Diggin this project!
I just read this entire thread between last night and this morning. Your work quality is absolutely outstanding! LIVE the Escalade console addition, that makes the interior VERY nice!
Really dig the turbo and all your work into cleaning up the engine bay.
I have a bright red RCSB also; mine's a 2011. This project is quite an inspiration!
Old 08-08-2018, 07:18 AM
  #312
ILuvJDM's Avatar
Thanks guys, appreciate the compliments. I have almost hit the one year mark of ownership, so I'm really hoping to make a WOT run before then.
Things left to do:
Swap 4L80e
Build rear-end
Alignment
Exhaust
Dyno tune
Old 08-09-2018, 12:34 PM
  #313
terravast4's Avatar
hope your dog is doing ok
Old 08-21-2018, 09:08 PM
  #314
ILuvJDM's Avatar
She is back to normal, can't even tell anything happened other than the lump under her neck skin where they put the pacemaker. Now we are prepping for her next surgery to remove a huge bladder stone... Also found out the girlfriends father has to have heart surgery in the next few weeks. When it rains it pours I guess.
Decided to tear apart the differential and tackle that job. Install kit shows up tomorrow, but still need to order the 3.90 gears
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-ndrt1ai.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-qiwnnln.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-6mzrrmm.jpg
Install list is:
Trutrac
3.90 gears
Yukon axles
All new bearings
Main cap stud kit
Crush sleeve eliminator
TA girdle cover
1350 yoke
Old 08-21-2018, 09:53 PM
  #315
100% Redneck
RedXray's Avatar
Received 1,331 Likes on 793 Posts
Install list is:
Trutrac
3.90 gears
Yukon axles
All new bearings
Main cap stud kit
TA girdle cover
1350 yoke
That's on my to do list also (just gears and trutrac).
I had 3.90 gears in my 1969 390 AMX they were the perfect ratio for that car.
Do a step by step tutorial to help an old guy out lol
Old 08-22-2018, 12:57 PM
  #316
terravast4's Avatar
Install list is:
Trutrac
3.90 gears
Yukon axles
All new bearings
Main cap stud kit
TA girdle cover
1350 yoke
I thought I saw a rear end in your garage with moser axles and a girdle cover. am I crazy?
Old 08-22-2018, 03:55 PM
  #317
ILuvJDM's Avatar
No, not crazy. I had built that a while ago but made some mistakes and had a slight whine and bearing noise. So I stripped all those parts out and going to redo it. Also, that axle wasn't prepped very well before paint, so it rusted and just looked like ****, the one in this truck is much nicer
Old 08-23-2018, 12:35 PM
  #318
terravast4's Avatar
sucks doing things twice. been there. and you are a perfectionist!!
Old 08-26-2018, 07:08 PM
  #319
ILuvJDM's Avatar
Sometimes I feel like its a curse, because I stress over dumb **** and redo stuff a lot if I'm not happy
Ordered the 3.90 gears at like 9pm Friday night, and they showed up Saturday morning. Summit is the ****
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-mhoqan4.jpg
Pressed on the new bearings and then used the press to set the ring gear and torque the bolts down
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-avoaffk.jpg
Setup bearings on the pinion
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-gxtvbbd.jpg
Here's the final install pattern. 0.033" shim, 0.006" backlash, and 16in-lbs of pre-load on the pinion bearings.
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-wsp3e0z.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-bxiutyj.jpg
Went for a drive after getting it all back together and I didn't hear a sound from the rear end. I could hear my tires on the road when next to a concrete barrier, so I know I should have heard a bad rear end sound.
I hope this one lasts and is quiet, my last install was full of whine and bearing noise, but I noticed that within the first 5mins of driving it.
Old 08-26-2018, 08:59 PM
  #320
That pattern looks textbook perfect! Please report how you like the 3.90's. That's exactly what I plan to put in my 2011.
What is the diameter of your tires?
Quick Reply: ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods
