I hope I'm not late for work!
Old Jul 28, 2014 | 09:51 PM
  #431
Atomic's Avatar
I have a gauge for that
2 step setting would depend on what the track is like and your torque converter. Typically with turbo setups its between 3000 and 3500.
Old Jul 28, 2014 | 11:03 PM
  #432
Denali08's Avatar
Originally Posted by smokeshow
Mine is set to 3500, but everyone's setup is different. When myself and Atomic get on the 2 step, we have 4 brakes holding the torque back...makes it easier to hold boost. You can try running hydroboost and/or swapping to disc brakes, but that still may not be enough. Looking at your signature now, looks like you're a 4wd....so just put it in 4 and build all the boost you want
Is there a direct install rear disc brake conversion kit without having to change the master cylinder or anything else? Similar to this:
http://www.summitracing.com/int/part...silverado-1500
I read in FAQ @ summit the following:
Q: Can I use a master cylinder from a disc/drum brake system with a four-wheel disc brake system?
A: No. A master cylinder designed for four-wheel disc brakes is required to supply the proper fluid pressure and volume.
Sorry for thread hijack.
Old Jul 28, 2014 | 11:13 PM
  #433
smokeshow's Avatar
Mod with training wheels
Just try 4wd lol. It will probably hold just fine.
Old Jul 28, 2014 | 11:20 PM
  #434
Denali08's Avatar
Ok, just got it. It should hold better in 4wd, you're saying. Will try it.
Thanx.
Old Jul 29, 2014 | 06:00 AM
  #435
Atomic's Avatar
For what its worth I have SUV disc brakes on the rear and 05 brakes on the front. Total upgrade cost was probably around 500 bucks and my brakes are awesome.
Old Jul 29, 2014 | 06:14 AM
  #436
Denali08's Avatar
Which year SUV and was it direct fit swap?
Stock master cylinder?
Old Jul 29, 2014 | 09:12 AM
  #437
Atomic's Avatar
2005 tahoe I think, its the 13" dual piston setup. I did notice the rear will grab first when I have the stock brakes, probably because the factory rears are single caliper and these are dual so a difference in volume.
Now that ive done the fronts I guess they are about the same. Hard to tell which set of tires locks up first
Direct swap on both front and rear, stock master cylinder, used hydrobooster from somewhere.
Old Jul 29, 2014 | 08:19 PM
  #438
Atomic's Avatar
Looks like I am back to street truck status!
Old Jul 29, 2014 | 08:46 PM
  #439
oakley6575's Avatar
But it isn't black
Old Jul 29, 2014 | 08:48 PM
  #440
Atomic's Avatar
Yea I dunno if I want to spray paint the filter....thought about it though
