I hope I'm not late for work!
#432
Mine is set to 3500, but everyone's setup is different. When myself and Atomic get on the 2 step, we have 4 brakes holding the torque back...makes it easier to hold boost. You can try running hydroboost and/or swapping to disc brakes, but that still may not be enough. Looking at your signature now, looks like you're a 4wd....so just put it in 4 and build all the boost you want
http://www.summitracing.com/int/part...silverado-1500
I read in FAQ @ summit the following:
Q: Can I use a master cylinder from a disc/drum brake system with a four-wheel disc brake system?
A: No. A master cylinder designed for four-wheel disc brakes is required to supply the proper fluid pressure and volume.
Sorry for thread hijack.
#436
#437
2005 tahoe I think, its the 13" dual piston setup. I did notice the rear will grab first when I have the stock brakes, probably because the factory rears are single caliper and these are dual so a difference in volume.
Now that ive done the fronts I guess they are about the same. Hard to tell which set of tires locks up first
Direct swap on both front and rear, stock master cylinder, used hydrobooster from somewhere.
