I hope I'm not late for work!
#143
put a speed sensor on the turbo! that would be very interesting to see. idk about yours, but with the ams odd dealings on my truck it is very audibly (sp?) noticeable when the wg is open partially and all the way.
#144
Wanna donate $400 and machine the compressor cover for one?
I looked at the dyno data again last night, and after we fixed the issue of it spinning on the dyno it picked up close to 100ftlbs peak torque when I added 2 degrees at the same rpm.
#146
I dont think I have room to put another gauge anyway
If my shortblock sells ill buy one
Also I need to come up with a better way to monitor backpressure...the copper tube keeps snapping off. Apparently copper doesnt like 1500 degree exhaust...
#148
Got it aligned today, here are the specs:
He couldnt get caster any closer because it was maxed out getting the camber right...
Also heres an idle vid: Turbo Silverado Idle - YouTube
toe it and blow it haha or set the toe and let it go
I know this was PAGES ago but when you go to slap your aligner you should be armed with the facts haha. that caster spread was extremely unacceptable and it shouldve never left the bay. that camber spread is "technically" ok but I dont like seeing more then .3 spread on camber.
basically the rule is the vehicle will pull to low caster high camber and your not supposed to have more then a .5 spread combined, depending what school you went too they want you to "compensate" for road crown and have a slight favour to the left but I consider that lazy alignment and I always set mine dead even
edit to add:
if you come here, i'll do your alignment for you but you gotta take me for a ride haha
#149
Thanks for the alignment input guys, I plan to get the bushings and arms roger linked to so there is some adjustability in the setup. I have just been really busy lately with starting a new job and moving so I havent had time to have the truck down. In the alignment guys defense he was not happy with how it came out, but if the adjustment is maxed out its maxed out.
Ran at my local track for the last time before I move last night. Didnt touch the tune at all, just increased my 2step 200 rpm each time (from 3000 to 3200 to 3400) and adjusted my traction bars some before the first run. First was 6.715@108 with a 1.7, second was 6.55@109 with a 1.62, and last was a 6.41@110 with a 1.51. I did a small burnout on the last one (usually dont do one at all). Left on 12psi and it spun some when boost hit 17 before it shifted. Only have about 15 degrees of timing in it.
7/19/2013 White Turbo Truck Holiday Beach - YouTube
The guy next to me blew his motor and sent fluid all over the track so they shut it down after this.
