I broke'did my toy... Kenne Bell/370 rebuild
Old Jan 5, 2025 | 08:25 AM
  #251
smokinlmm's Avatar
Ouch on suspension braking and cutting driveshaft. That blows. Brakes look good, bet they perform much better than the previous setup. I need to do that rear brake conversion on mine. Truck looks great! I know that that trip to Nashville had to be fun, I want to go to LS fest, I bet that was a good time.
Old Jan 6, 2025 | 09:18 AM
  #252
BigKID's Avatar
Those tires look pretty worn...
The SC3 does not have a uniform tread depth across the tire. The outside tread blocks are shallower and the outside half of the tire basicly becomes a slick at half worn. If you look, you can see the outside tread indicators. However, these tires are nearly 3 years old so likely starting to heat cycle out. I will likely have to replace them before the tread is completely gone.
As for the rear brakes, What about a dual piston set up like the SS trucks used? same as what's on the Suv's.
I considered the SUV dual piston calipers but they have slightly more piston area than the non-F44 calipers I was removing. I also had issues with the rear wanting to come around on heavy braking from higher speeds so thought a little less bias on the rear would help that too. I have not been on course with the new rear brakes yet but from some street testing, braking seems to be more balanced now.
Old Jan 6, 2025 | 09:59 AM
  #253
BigKID's Avatar
The OBS front conversion for 15's?
I went to my first LS fest in Bowling Green in 2013 for the Truckin Throwdown. I didn't go in 2014 because the truck was hurt but have been every year since 2015. As a participant, I feel it is getting too big and a bit hectic. If it were not for half the autocross being split up at NCM, I may stop going as a participant. However, as a spectator, there is no lack of entertainment. Plenty to watch from drag, autox, drifting, burnouts, offroad, dyno, carshow and a huge vendor midway.
Old Feb 10, 2025 | 09:11 AM
  #254
BigKID's Avatar
Harness bar is complete and installed. It was a lot of work, trial and error getting it to fit the way I wanted but I am pleased with the results for my first attempt. Well, except for the paint color. The cap was an exact match to the interior trim but dried significantly lighter. I do plan to get some vinyl to wrap the door bars, as I can already tell the buckles are going to chip it up if not super careful, so can do some color correction there.
Final fitment before seats...
Old Feb 11, 2025 | 10:37 AM
  #255
Atomic's Avatar
I have a gauge for that
Looks good!
Old Feb 11, 2025 | 11:02 AM
  #256
1FastBrick's Avatar
Custm2500's Rude Friend
How did you attach it to the cab and or frame?
Old Feb 12, 2025 | 12:51 PM
  #257
BigKID's Avatar
Currently bolted to cab floor only with 4x4x3/16 plate and 4-1/2" bolts at each attachment point. One race I do every year, rules would put me in a different class if attached to frame. I am not sure how much stiffer it would make the frame at those four points anyway. Solid cab mounts would likely work as well and not break the rules. I am confident this is as strong or stronger than the seat integrated restraints in the event of a crash. However, I am considering reinforcing the underside of the cab floor at the attachment points.
Old Feb 12, 2025 | 01:08 PM
  #258
smokinlmm's Avatar
A backing plate would help a ton.
Old Feb 12, 2025 | 01:14 PM
  #259
BigKID's Avatar
I agree. Next time I break out the fab tools for the pending rear suspension work, I plan to cut out some backing plates.
Old Feb 12, 2025 | 04:29 PM
  #260
Atomic's Avatar
Take you about 3 minutes and itll be shipped to you...
