Home Grown Boost and More
Old Dec 16, 2011 | 06:57 PM
  #81
03RCSB's Avatar
Originally Posted by bmd_CL
Looks like its running very nicely man. As for that parts list lol? jk you dont have to put it up if you dont want too
Ah no big secret man, sorry for the delay on putting it together, I just haven't sat down and typed it all up. I will try to get to it this weekend.
Old Jan 2, 2012 | 06:11 AM
  #82
kr1s's Avatar
Lol just scan all the notes! save yourself alot of time
Old Jan 7, 2012 | 07:17 PM
  #83
03RCSB's Avatar
Well 800 boosted miles later and I was finally able to get some logging done today to send back to Justin. Truck hasn't had a single issue since the install, only time i'm opening the hood is to show off Tune seems good so far, just a slight stumble at partial throttle of boost due to richness but wot or past that is fine and pulls hard, I'm sure after the update it will feel like a whole new truck again.
The truck is due for tires/trans swap and all that but its taking a backseat so my daily can get some much needed maint and upgrading.
Picked up a 2500 from my father about a year ago, he bought it brand new, babied it and offered it to me for a price too good to pass up when he bought a new one. Was 100% stock so I replaced the shocks, did a tune up/ cranked the tbars until level and fixed some minor issues here and there.
Scored some H2 rims/tires off craigslist for $300 and although they look great on the truck, as you can see in the test fit, they rub with even the slightest turn of the wheel.
Suspension lifts are limited because of the backspacing of the H2 rims so I just ordered up a 3" PA body lift and some gap guards. While i'm in there I will be doing upper/lower balljoints, inner/outer tire rods and the pitman and idler arm. Hope to knock it all out and get the h2's on there next weekend, pics will be coming soon there after.
Old Jan 7, 2012 | 07:24 PM
  #84
A Low Dime's Avatar
13 Second Truck Club
What size tire are on those H2 rims in the picture?
Old Jan 7, 2012 | 07:26 PM
  #85
03RCSB's Avatar
315/70/17 stock size for an H2. Work out to be about 34.5".
Forgot to mention the rims were just flat black when I got them but will be getting sprayed with bedliner this weekend before going on.
Old Jan 7, 2012 | 08:26 PM
  #86
kr1s's Avatar
Old Jan 7, 2012 | 08:47 PM
  #87
03RCSB's Avatar
Long overdue but here is the parts list. I may have left some small things out here and there but nothing you cant find with a quick Hardware store run.
From Summit
(4) MSD Ignition 3304 - MSD Replacement Boots and Terminals $8 each
Spectre Performance 8168 - Spectre Performance Air Filters $25
Jones Exhaust FLX3010B - Jones Exhaust Systems Flex Tubes $32
Jones Exhaust FLX2004B - Jones Exhaust Systems Flex Tubes $13
(3) Summit Racing SUM-350114 - Summit Racing® Heat Tape $9 each
Summit Racing SUM-621005 - Summit Racing® Exhaust Tubing Mandrel Bends 2" J Bend $15
Summit Racing SUM-640030 - Summit Racing® Exhaust Tubing 3" straight exhaust pipe 4ft $17
(3) Summit Racing SUM-G2990 - Summit Racing® Weld-In Oxygen Sensor Fittings $6 each
Moroso 63650 - Moroso Cooling System Expansion Tanks $80
MSD Ignition 5553 - MSD Street Fire Spark Plug Wire Sets $42
From Ebay
Seller: mandrelexhaustsystems
14ga 2.5" Aluminized Mandrel Bend Pack
16ga 3" Aluminized Mandrel Bend Pack
(1) 14ga 2.5" Mandrel L
$170
Seller: wyntonm
44mm Wastegate 4-7psi $90
44mm BOV with 3" pipe $80
2.5" and 3" Mild Steel V Band kits $60
Seller: JustIntercoolers
31x12x3 Intercooler with pipe kit (All Straight Silicone Couplers) $250
From Frozenboost
4" to 3.75" reducer
3.75" to 3" reducer
2.5" to 3" 90 degree reducer
(2) 3" hump Hoses
(2) 3" 90 degree Hoses
4" Tbolt Clamp
(2) 3.75" TBolt Clamps
2.5" TBolt Clamp
Economy Rubber
1/2" NPT to 3/4" Barb 90Degree
1/4" NPT to 1/2" Barb 90Degree
$25
Autozone/Lowes
Radiator Cap $6
3' 1/2" heater hose $4
3/4" x3/4" Sharkbite Elbows (2) $5
1"x1"x3/4" Shark Bite T $8
1/2" Barb Splice
5/8" Barb Splice
8ft 5/8" heater hose
4ft 3/4" heater hose
$31
Ebay: LS1 Flange Kit $40
TSP Walbro Pump Kit $135
Trick Performance Oil Line Kit $120
Ebay: Siemens 60lb Injectors and Pigtails $400
100ft Heat Wrap $90
Ebay: Turbo Blacnket $60
Nelson Performance: Magnum T70 Turbo $600
Ebay: 2.5" x 4" Flex Pipe $20
Old Jan 7, 2012 | 08:53 PM
  #88
BlownChevy's Avatar
blownerator
25 Year Member
Nice work! You definitely want to move that maf at least 10 inches from the front of the throttle in a straight air path. You will have issues with tuning and drive ability otherwise.
Old Jan 7, 2012 | 09:01 PM
  #89
03RCSB's Avatar
Thanks, I have had a few people tell me about the tuning issues with the MAF in the spot I have it now. Aside from a small rich spike as soon as it enters boost I couldn't be happier with it. Will definitely keep an eye on the part throttle driving though and if anything seems off at least I have an idea on what to tackle first.
Old Jan 8, 2012 | 06:37 PM
  #90
03RCSB's Avatar
Sprayed one rim today just to see how it would work out. Not perfect but more than good enough for my daily beater.
Primered
Still wet with two coats of Rustoleum bedliner
More to come next weekend
