Hey there Delilah
Old Jan 18, 2013 | 07:14 PM
  #31
addy's240's Avatar
Do you happen to remember the size of that rear tire? Looks ******* awesome. The wheels are 18x8 right?
Old Jan 18, 2013 | 07:18 PM
  #32
TimDave217's Avatar
yea, there 18x8's and the tire is a 305/45/18 Nt05r, what would be more awesome is if the damn thing ran
Old Jan 19, 2013 | 03:59 AM
  #33
Tydriver's Avatar
Have you tried to jumper the starter with the key on? This will determine if the starter is good or not. This will answer a few questions and help the troubleshooting and narrow down where you need to focus.
I was also going to recommend in addition to jumping the starter; to hold the key in the start while shifting the transmission through P-D, that will tell you if the neutral safety switch is whacked, unless of course it's completely disconnected or bad, if its simply misaligned it should try to turn over when you hit the right spot.
Good luck !
Old Jan 20, 2013 | 02:51 PM
  #34
TimDave217's Avatar
Got it all figured out!!! It was the damn starter solenoid. I toon the starter off took it to auto zone and had them do a test and it passed so I had him run another 5 times on it took it back and put it on and started right like that. While I'm writing I'd like to thank everyone for chiming in and putting in there .02 cents of advice!
Old Jan 20, 2013 | 03:22 PM
  #35
milkey57's Avatar
Bad *** glad shes runnin! Now lets see some vids
Old Jan 20, 2013 | 04:41 PM
  #36
TimDave217's Avatar
Just dropped it off to get the cold side piping done and tune. It'll be Bout next weekend before I pick it up .
Old Jan 22, 2013 | 10:29 AM
  #37
TimDave217's Avatar
So just a quick update, finally got the truck up to the tuner like i said before, i'll be up there this coming week to pick it back up and take her home!!
here's a pic dropping it off.
Also as i was finishing up my build my buddy started pulling the motor on his c5 vette kinda funny how it is all happening in a very small garage with just enough of everything in it.
other than these update's i have nothing. ill get video on the way back from kc this weekend.
some future things i'd like to get on this right now is an intake tube and bigger filter does anyone have any recommendations maybe???
and a vacuum block so i dont have so many T-connectors everywhere.
Old Jan 22, 2013 | 03:43 PM
  #38
oakley6575's Avatar
I know I've said this before, but good looking truck. How much boost is the tuner running through the truck?
Old Jan 22, 2013 | 03:51 PM
  #39
TimDave217's Avatar
well, right now there building a solid cold side for it so i have the least amount of couplers on it, then when i go up there to get the truck there gonna tune it, but were gonna have a low boost setting between 9-12# then a high boost setting up at about 20# or higher
Old Jan 24, 2013 | 04:57 PM
  #40
TimDave217's Avatar
Pics from the cold side being built. Just a little update.
READY FOR IT TO RUN
