Graeme's Daily Driver 2003 4x4 Build
Old Jul 18, 2016 | 10:38 AM
  #371
GM1697's Avatar
Originally Posted by flatblack83
Alot of guys use these too, i would of thought they would fit fine. Can you shorten both sides of the y pipe so its closer to the motor. Re expand the ends and move the o2 bung back..? Then add a piece to the end so you can still use the nice flange. Its cutting it up but should still work, That should move it forward a few inches to clear the shaft as long as its away from the trans pan. Or won't forward help, i'm not sure if the front shaft is a straight shot on a lower truck closer to stock 4x4 truck...? Maybe have the left side of the y bent down more so you can aim the pipe down more under the shaft.
Sorry just trying to help some, on my stainless works i had to aim my driver side pipe down some to clear my deep pml trans pan. Mine didn't hit the shaft but ran into other things..lol.
I'm hoping I just got a defective one... But honestly I think I may be forced to do some cutting and welding to piece something together. It can easily be made to fit, but then again it was made for my truck... it should bolt on properly...
Old Jul 19, 2016 | 07:00 AM
  #372
Jlipton72's Avatar
Lol, all the bullshit you gave me about southern truck this your trucks a rot box that blah blah blah mister broken manifold stud... You were there for the install on my truck, the crossover pipe hit the front driveshaft on mine as well, hit the frame on the passenger side, hit the steering shaft on the drivers side. Learned my lesson
Old Jul 19, 2016 | 07:23 AM
  #373
GM1697's Avatar
Shoulda learned my lesson...
Old Jul 19, 2016 | 10:54 AM
  #374
03sierraslt's Avatar
Originally Posted by GM1697
Added some safety features considering there is 100 extra feet of wiring under the hood now. Was gonna rig up some sort of mount, but then it fit perfectly in cup holder. So I plan on just keeping it there
If you made real power that **** would t stay in the cup holder.
Old Jul 19, 2016 | 12:45 PM
  #375
GM1697's Avatar
what a dick...
hahah
Old Jul 19, 2016 | 07:42 PM
  #376
GM1697's Avatar
well Pat pushed me over the edge....
slapping a blower on this bad boy, as you see my entire nitrous system is for sale.
need to figure out a fuel setup because the maggie i'm getting is a returnless setup, ill be making a separate thread for this.
Old Jul 19, 2016 | 08:02 PM
  #377
Atomic's Avatar
I have a gauge for that
My whipple is a returnless rail but that didn't stop me :p
Old Jul 19, 2016 | 08:09 PM
  #378
GM1697's Avatar
well head over to my other thread and learn me some of your knowledge
Old Jul 19, 2016 | 08:15 PM
  #379
1FastBrick's Avatar
Custm2500's Rude Friend
All you need to do is use return style rails...
Old Jul 20, 2016 | 10:31 PM
  #380
GRRR65GTO's Avatar
Whats the issue with return less rails? I converted my return rails to return less cause of my adjustable regulator. Wanna trade?
