Graeme's Daily Driver 2003 4x4 Build
#371
Alot of guys use these too, i would of thought they would fit fine. Can you shorten both sides of the y pipe so its closer to the motor. Re expand the ends and move the o2 bung back..? Then add a piece to the end so you can still use the nice flange. Its cutting it up but should still work, That should move it forward a few inches to clear the shaft as long as its away from the trans pan. Or won't forward help, i'm not sure if the front shaft is a straight shot on a lower truck closer to stock 4x4 truck...? Maybe have the left side of the y bent down more so you can aim the pipe down more under the shaft.
Sorry just trying to help some, on my stainless works i had to aim my driver side pipe down some to clear my deep pml trans pan. Mine didn't hit the shaft but ran into other things..lol.
#372
Lol, all the bullshit you gave me about southern truck this your trucks a rot box that blah blah blah mister broken manifold stud... You were there for the install on my truck, the crossover pipe hit the front driveshaft on mine as well, hit the frame on the passenger side, hit the steering shaft on the drivers side. Learned my lesson
#373
Shoulda learned my lesson...
#374
#376
well Pat pushed me over the edge....
slapping a blower on this bad boy, as you see my entire nitrous system is for sale.
need to figure out a fuel setup because the maggie i'm getting is a returnless setup, ill be making a separate thread for this.
