First Time Rebuild On LM7
Cranking the engine does squat for building OP. Just crank it up and cringe through the rattling. Use non-synthetic oil for break in, most important is too resist the urge to stomp on the gas pedal for at least 500 miles.
Actually this statement can be argued also. I am not sure where but there is a break in thread on here that someone posted saying you should beat on to help seat the rings properly. Any oil on sale from walmart is what my engine builder told me to use for the break in. Its always a good idea to run something with a high zinc content if this is a high performance engine.
What i was taught atleast at Wyotech was that you wanna break the cam in for about 15min then after that let all hell break loose.. Better to find out if something is gonna break now than later.
I am pretty sure breaking in a cam only applies to non-roller cams. Incase you didnt know the LS series motor is a roller motor
The only new parts are the rings and bearings.
Pistons, cam, lifters are reused.
So how many miles using dino. When can I use the good stuff? 500 miles, 1000?
I know Royal Purple says you can use it from the very beginning. But have heard you shouldn't like ya'll said.
Probably pick up some Castrol GTX.
What about viscosity? I have always used 10w30 but may go with 5w30 like the cap says.
