Droppin More Quarters Then Michael J Fox @ a Parking Meter (pic heavy)
Old Dec 14, 2013 | 01:23 PM
  #31
RS/SS 4.8's Avatar
10 Second Truck Club
Huh thats new to me lol. You can probobly get some block offs on ebay or one of the sponsers on the right.
Old Dec 14, 2013 | 04:43 PM
  #32
sprayed99's Avatar
You need to go by the marks on the pushrod length checker.. Do not measure the OL of the checker because that is not how it is designed to work and will be inaccurate. When the checker is at its shortest, it is 6.800", and each full turn is .050". Check out post #2
comp cam pushrod length checker, how to use? - Corvette Forum
LMAO it is not 6.800" I have atleast 15 of them at the shop and they range from 6.787" to 6.833"
Old Dec 14, 2013 | 04:55 PM
  #33
kretty's Avatar
Originally Posted by AUTOT3K
No my old heads the coolant hole is like welded over or riveted so theres no plug to transfer over
junk yard or dealer to buy a crossover tube and bolts?
What brand 4.10's and locker is that?
Old Dec 14, 2013 | 06:17 PM
  #34
AUTOT3K's Avatar
The dealer carries the block offs ill post the part number later this evening theyre about $13
its a detroit locker and richmond excel gears
Old Dec 14, 2013 | 06:22 PM
  #35
AUTOT3K's Avatar
I didnt make the progress today that I had wanted too.
Those arp studs added a ton of time! And the stage 8 locking bolts for the headers dont help either
got both heads on and torqued down and got the left header on and locks on
Old Dec 14, 2013 | 08:37 PM
  #36
AUTOT3K's Avatar
Steam Vent Block Off's - 12602540 (you need 2)
O-ring Seals - 12551933 (you need 2)
Old Dec 14, 2013 | 08:58 PM
  #37
Byrdman11's Avatar
Awesome Build!!!!
Old Dec 14, 2013 | 09:27 PM
  #38
AUTOT3K's Avatar
aren't push rods measured from where the "ball point" ends? so if you measured tip to tip it could add some if that's true.
I'll try both ways, measure overall and count turns...see where we end up
Old Dec 15, 2013 | 03:15 AM
  #39
oakley6575's Avatar
You can L your AO. Comp didn't design their tool to be measured with calipers so I'm not sure why anyone would. The correct way to use the tool is to count the turns from its base position which comp built to be 6.800".
Old Dec 15, 2013 | 02:03 PM
  #40
diRty?biRd's Avatar
[QUOTE OAKLEY y6575;5171985]You can L your AO. Comp didn't design their tool to be measured with calipers so I'm not sure why anyone would. The correct way to use the tool is to count the turns from its base position which comp built to be 6.800".
[/QUOTE]
What Oakley said.... they do make them in different lengths though....
5.800-6.800
6.800-7.800
7.800-8.800
