denali rcsb
Old Oct 28, 2014 | 07:38 PM
  #51
denalircsb's Avatar
You will like it. Fill out an Ask Chris form on their site and tell them how you will use the truck and your goals. They will set you up
Thanks, will try that!
Old Dec 18, 2014 | 05:00 PM
  #52
denalircsb's Avatar
Havent done an update in a while since i havent had time to do any work but i finally have all the parts to finish up the engine so when they get here ill post some pic of the engine finished. And i have decided to change to an 4l80e transmicion cause my brother has almost the same power in his truck and he has broken it twice in a short amount of time so i didnt want that.
Old Mar 24, 2015 | 10:46 AM
  #53
denalircsb's Avatar
Finally working on the truck. I have it almost done now, gonna put up some pictures i took along the way.
Engine on the frame
For a transfer case i used one out of a 09 AWD Yukon since the output shaft on the 4l80e is different then the 4l60e i couldnt use the original one without modifieing the output shaft so i went with this trasfer case. I just had to put in the transmission another speed sensor cause the older ones had the sensor in the transfer and the newer dont so i just put in the sensor as if it would be a 2wd and it seems to work.
With the drive shaft i got lucky, went and got one out of an 04 4WD Tahoe and it fitted without having to cut it up!
This is how it sits now, have done a bit more to it but not much. Will post some more pics when i get some. Its running and driving now seems all to work. Quadrasteer seems to work good also. Wanna get it to the muffler shop today so i can start tunning a bit
And a pic of repairing the bed!
Old Mar 24, 2015 | 08:42 PM
  #54
DV2000NJ's Avatar
13 Second Truck Club
This is so awesome, great work man.
Old Mar 24, 2015 | 08:58 PM
  #55
denalircsb's Avatar
Thanks man!
Old Apr 8, 2015 | 07:57 PM
  #56
denalircsb's Avatar
Update:
I got it almost done now, just gotta do the buffing and i wanna do it tomorrow, and some interior work and shes done!!
Engine bay cleaned
How the interior looks now
Exterior
I wanna get it done this week so when its done im gonna put some more pics up
Old Apr 9, 2015 | 06:30 PM
  #57
Rafe19's Avatar
Looks awesome !
Old Apr 9, 2015 | 07:16 PM
  #58
denalircsb's Avatar
Originally Posted by Rafe19
Looks awesome !
Thanks man!
Old Apr 9, 2015 | 09:49 PM
  #59
slick_sierra's Avatar
Awesome build tire size looks pretty beefy, what's exactly does a 6.0 to ls3 conversion consists of besides bigger Pistons
Old Apr 10, 2015 | 02:03 PM
  #60
denalircsb's Avatar
Thanks!!
You'll also need to change the heads and intake and thats it if you build it off a 6.0.
