Dark Star - 2014 Silverado RCSB
Old Feb 23, 2015 | 11:17 PM
  #241
bigsapper's Avatar
Originally Posted by bigsapper
Hmmmm, I wonder if a C7 vette converter will bolt up?
$350 + $100 core and supposed to stall to 2500.
Old Feb 24, 2015 | 01:06 PM
  #242
Noah Burns's Avatar
Behind what engine?
Personally I've never been one to be cheap where converters are concerned, you can do whatever you like but your best bet is to do it right the first time
Old Feb 24, 2015 | 01:23 PM
  #243
bigsapper's Avatar
Not sure what's "being cheap" (you meant that as a pejorative, not as being less expensive, right?) about using a higher stall factory converter?
In any event, it won't work. However, the ZL1 converter is also a multi-disc clutch with a touch higher stall, about 2000. I'm wanting to retain stock manners so something less than 2500 is what I'm looking for. With the added benefit of being multi-disc it sure looks like a viable option.
Old Feb 25, 2015 | 06:34 AM
  #244
Noah Burns's Avatar
Im saying that they're not a true performance converter, they are still a stock converter regardless.
The circle d converter in my truck foot brakes to 3000rpm and drives like a bone stock converter. Mileage has not been changed one bit since I put it in... You can go "bigger" and gain performance and retain stock naners as well... You just have to do a few minutes worth of research...
Old Feb 25, 2015 | 06:52 AM
  #245
bigsapper's Avatar
Do you have a single- or multi-disc?
Old Feb 25, 2015 | 01:28 PM
  #246
Noah Burns's Avatar
single disk, I wasn't planning on going with a power adder when I bought the truck so I went with a single. That plan changed since then and I'll end up with a multi but that doesn't really change the driving characteristics from my past experiences.
Old Feb 26, 2015 | 06:29 PM
  #247
bigsapper's Avatar
Old Feb 26, 2015 | 08:01 PM
  #248
Noah Burns's Avatar
where you going to mount it, is anyone making a pillar pod for our models yet?
Old Feb 27, 2015 | 07:05 AM
  #249
bigsapper's Avatar
I have no idea.
Old Feb 27, 2015 | 10:21 AM
  #250
Noah Burns's Avatar
Someone makes a wideband that the gauge part is rectangle I thought about finding its dimensions and seeing if it could be made to fit in the little left side cubby hole, but that's where the NX nitrous switch panel goes so idk where I'd mount anything either since nothing's really out on the market for us yet.
