can a 5.3 or 6.0 replace a 5.7 vortec?
Old Jan 24, 2011 | 02:56 PM
folklohr's Avatar
Default can a 5.3 or 6.0 replace a 5.7 vortec?
looking for advise on a possible motor swap. got a '97 suburban with high miles(237K) and it may finally give out soon. the truck is worth keeping, as the rest of the truck is in great shape. wondering if i should replace the motor with another 5.7 or swap to a 5.3 or 6.0. asking your advise on what would be involved to do the swap. thx in advance.
Old Jan 24, 2011 | 03:03 PM
Mangled03gmc's Avatar
Baltimore Whore
Sure can, but you will need to fab some things up, change some wiring around..
Old Jan 24, 2011 | 03:30 PM
jared91's Avatar
you will need, motor, motor mounts, flexplate and stall and converter, harness, pcm since yours is a 97, iirc brakebooster, fuel lines, radiator, ac compressor and all that stuff, and i think thats all there might be more that i can think of off the top of my head
Old Jan 24, 2011 | 04:26 PM
iamkeniff's Avatar
https://www.performancetrucks.net/fo...d.php?t=447052
read through this...works wonders with a write up. its not a 5.7 but its the same thing.
Old Jan 24, 2011 | 04:29 PM
iamkeniff's Avatar
http://hotrodlane.cc/PDFFILES/Lisa%20Tahoe.pdf
you need to read through this...this is perfect
Old Jan 24, 2011 | 04:34 PM
aeorozco's Avatar
Originally Posted by folklohr
looking for advise on a possible motor swap. got a '97 suburban with high miles(237K) and it may finally give out soon. the truck is work keeping, as the rest of the truck is in great shape. wondering if i should replace the motor with another 5.7 or swap to a 5.3 or 6.0. asking your advise on what would be involved to do the swap. thx in advance.
Why would you want to go back down in size from a 350ci 5.7L tbi to a 325ci 5.3FI ? Just curios, dont see many people going smaller with the builds....
Old Jan 24, 2011 | 04:53 PM
Robert91RS's Avatar
If the 5.3 wasnt an improvement over the 350 Gm wouldn't have made the swap....more power, less weight, more efficient. Displacement is great but it isn't everything.
Old Jan 25, 2011 | 06:56 PM
folklohr's Avatar
this is exactly what i was looking for. thx for your help. much appreciated
Old Jan 25, 2011 | 07:50 PM
iamkeniff's Avatar
no problem
Old Jan 28, 2011 | 05:32 PM
Low91's Avatar
Go to LS1truck.com, they have a whole section just for LS into 88-98 swaps. I couldn't have done mine without all the help I got from there.
