C3 build
Old Oct 2, 2012 | 01:21 AM
  #901
AndysC3's Avatar
I work that weekend.
Old Oct 2, 2012 | 10:08 AM
  #902
AndysC3's Avatar
vid of my wot. My laptop died so I wanted to make a vid. But my last update I set the MPH shift too high so it bounced off the rev limiter. Its best to watch it full screen on 720P
Old Oct 2, 2012 | 02:40 PM
  #903
black00chev's Avatar
Slowest turbo build ever!
sounds soooooo good!
Old Oct 2, 2012 | 05:07 PM
  #904
darnie's Avatar
now thats more like it
Old Oct 3, 2012 | 11:03 PM
  #905
AndysC3's Avatar
Valet mode/two step activation switch.
Just loaded the updated tune to activate the two step. Set it at 2600rpm for now. I'll raise it if it works
Old Oct 4, 2012 | 02:14 AM
  #906
AndysC3's Avatar
So, Still losing major fuel pressure. Especially in 2nd gear. I think my intake is starting to go. Still running the stock wiring. When I turn the truck on, the pumps prime, then I lose all fuel pressure when they stop. so What should I do now?
Old Oct 4, 2012 | 03:12 AM
  #907
smokeshow's Avatar
Mod with training wheels
Does your fuel system have a check valve? What was fuel level when pressure dropped?
Old Oct 4, 2012 | 11:52 AM
  #908
Check you FPR as well. Mine was letting fuel through the vaccum line into the intake and wouldnt hold a steady pressure. And it could very well be the pump also. I had both go bad at just about the same time.
Old Oct 4, 2012 | 02:32 PM
  #909
ak2007r6's Avatar
D1 is a great unit no doubt, can def make big numbers
Originally Posted by AKlowriderZ71
Agreed.
0-60 in a Procharged Sierra C3 - YouTube
Nice!
Old Oct 4, 2012 | 03:07 PM
  #910
AndysC3's Avatar
The intank has a check valve. Before I added the 044 it would hold around 40psi. the fuel tank was full.
