C3 build
Old Jul 22, 2012 | 11:41 PM
  #551
AKlowriderZ71's Avatar
11 Second Hall Moniter
Originally Posted by AndysC3
heres a pic showing how much shorter the fast injectors are. and the current 1/2" spacer
the spacer only fits on the bottom and is too big to fit in the fuel rail.
Don't know if this will work or not, but try it.
Remove the blue o-ring from the top of the injector. Remove the o-ring from the spacer. If the inside diameter is close, swap them and try running the spacer above the injector.
It may not work, but I think it's worth a try. Just be careful to not damage any of the o-rings.
Old Jul 22, 2012 | 11:55 PM
  #552
AndysC3's Avatar
Already tried. The spacers won't even fit in the fuel rail. And even with the green o ring the injector just falls out. I'm ordering some 1/2 spacers form injectorconnection. Hope they get here soon. I really wanna go wot. Lol. At 55% throttle it'll be about 4200 rpm and I'm seeing 4-5 psi and it moves. On my one wot log I gwen it shifting at 5500, saw about 9psi, idc was at 150%, I know I know but afr was still 11.9. Would the 65 lb injectors be able to take me there? I'm hoping so for now. Or sell the 65 and get some 96lb injectors. Lol
Old Jul 23, 2012 | 12:05 AM
  #553
Haha, well don't get too impatient and go lean in boost. That won't end well, unless you just need an excuse to go forged.....
Is your fuel pressure maintaining when you're seeing 150% IDC? ****, I thought my 105% IDC was bad.......
Old Jul 23, 2012 | 12:28 AM
  #554
AndysC3's Avatar
Fuel pressure was around 52-53 psi. Before it was around 55 psi. Its hard to tell since my system is non referenced and the vette filter causes the fuel pressure to drop slightly during wot.
Old Jul 23, 2012 | 12:32 AM
  #555
At least the pressure is staying up, and that's a good thing!
We all know your injectors are too small, and the 65#'ers are a big step up. Just need to get them in there & find out where you stand.
Old Jul 23, 2012 | 12:36 AM
  #556
AndysC3's Avatar
yea. The fuel is a racetronix 255lph. Do you remember what Andys IDC was? I would like to shift it around 6300-6400. should be around 11-12 psi.
Old Jul 23, 2012 | 12:46 AM
  #557
Was in the 90's% at 5800-ish in 1st gear. IIRC, was 10-12 psi at that point. Was able to go a little higher rpm in 2nd and 3rd.
Old Jul 23, 2012 | 01:15 AM
  #558
AndysC3's Avatar
Hmmm, I may need to go with some 80s then
Old Jul 23, 2012 | 07:58 AM
  #559
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I may be interested in your injectors when you're done with them. They're a direct drop-in for me
Old Jul 23, 2012 | 08:31 AM
  #560
ak2007r6's Avatar
my injectors are ******... LOL
Hope the new spacer work for ya. I think they should take you to the shift points you want if not damn close.
