C3 build
Old Jul 19, 2012 | 09:10 AM
  #461
Vortec350ss's Avatar
Granted you have A LOT more going on with this build than most, but peopl erun 42's with boost quite frequently. Just get er done and shift it where the injectors start to run out of life. My guess is that it will be before 6k though...
Old Jul 19, 2012 | 09:58 AM
  #462
milkey57's Avatar
Originally Posted by AndysC3
Another thing this morning. go out to start the truck. and get a CEL. Checked the code and its P0200 Injector Control Circuit. and its running like ****. I shut it off. The injector clips are not clicking into place like they should. I may just get some USCAR pigtails and replace the stock plugs. Would it be bad to install the procharger with the 42s and a non referenced fuel system? Ill set the shift points to about 6k untill I can get the 65s in. Current IDC at 6k is 51% with about 20% E85 still in the tank.
I ran my 42's no boost ref with no prob when i had my ls1/p1 combo, you should be fine with them till you can upgrade later.
Old Jul 19, 2012 | 10:07 AM
  #463
AndysC3's Avatar
Yea, just have to wait a lil longer to get it to where I wanted it.
Old Jul 19, 2012 | 10:24 AM
  #464
milkey57's Avatar
Ya the waiting part sucks, but thats part of the game.
Old Jul 19, 2012 | 10:39 AM
  #465
AndysC3's Avatar
Yea, But I guess I can still install the procharger tomorrow. It will help ease some of the waiting lol.
Old Jul 19, 2012 | 10:58 AM
  #466
milkey57's Avatar
Lol DO IT
Old Jul 19, 2012 | 11:48 AM
  #467
AKlowriderZ71's Avatar
11 Second Hall Moniter
Just want to make sure that these are the pigtails that I will need to run the fast injectors.
Racetronix - Injector Connector Assembly USCAR
and this is the injector. You can kinda see the plugs
Yes, those connectors should work. (USCAR/EV6)
I think it would be a cleaner install with these. FAST: USCAR Type Connector Kit But they would be a little more work.
Old Jul 19, 2012 | 06:46 PM
  #468
AndysC3's Avatar
Thanks. and for a cleaner install, I have alot of heat shrink tube lol
Old Jul 19, 2012 | 07:21 PM
  #469
03sierraslt's Avatar
I put new ends on mine when I switched to the EV1 connectors, looks much better doing it that way and then there are no splices. You just need a crimper that is made for weather pack connectors.
Old Jul 19, 2012 | 09:26 PM
  #470
AndysC3's Avatar
Well I loaded the procharger in the back of the truck. Going to the shop after work to install. I'll set it to shift around 5800 at first and see how it does. Aiming for 11.3-11.5 afr to start with and a max timing of about 10*. What would be the max idc to be somewhat safe. I was thinking about 90%. Still have about 15-20% of e85 in the tank but its only 1/2 full. If I can get it running good I may go to the t&t Saturday afternoon if it doesn't rain.
