C3 build
Old May 12, 2011 | 11:05 PM
  #31
AndysC3's Avatar
Got everything buttoned up and the truck is running. has a nice smooth idle. Only hiccup was when I went to swap out the tstat, it was a two piece tstat and I had a one piece so it didn't fit. started looking at the old tstat and it was a 186* so I may just keep that one and get a retune since this tune is set up for a 160*.
Also, I need some opinions. The way I had my intake set up was a 4" 90* elbow and a 4" pipe to the MAF. I had to flip the upper radiator hose to get it to work. Now with the 90mm tb the hose is pinched between the intake tube and the tb. I could go back to my old K&N set up but that setup sucks lol. what are my options
Old May 13, 2011 | 03:15 AM
  #32
BadAssChevy327's Avatar
i dont understand why you went through with swapping intakes before you did the heads and cam? but how were the seat of the pants gain with the intake manifold?
besides that clean c3 mean. i like it.
Old May 13, 2011 | 09:01 AM
  #33
AndysC3's Avatar
I didn't do the heads and cam first because I haven't bought my torque converter yet. I decided to buy a daily driver instead lol. Next I'll install the tc, then the heads and cam.
Trying to swap out the tstat I lost a lot of coolant so I haven't been able to really get on it. But from my initial test it pulls a lot more from 4k up. Going to the track tomorrow night and we'll see how it does.
Old May 13, 2011 | 02:49 PM
  #34
AndysC3's Avatar
Got the coolant changed and took it for a test drive. Man this thing PULLS form 4k up. I had to go back to my old K&N set up for now. Still looking for ways to make the 4" work. Here are some pics of my progress.
Here is the breather tube that goes to the valve cover. Eventually I will install a catch can there. I used a 3/8 brass barb. the blue stuff is gasket maker to seal the hole
I used the vette fuel filter to convert the returnless fuel rail to return. Fuel pressure is steady 58-60.
and here is the egr delete that I made out of 1/8" aluminum. Works great.
Old May 13, 2011 | 04:42 PM
  #35
Tombstone's Avatar
The truck looks great but I have a question that maybe one of the c3 owners can answer. What is the defferince between the c3, denali, and the regular sierra?
Old May 13, 2011 | 04:48 PM
  #36
AndysC3's Avatar
thanks
The c3 was the first year the Y91(Denali) package was offered on the sierra so they called it the C3. The 02-04 Sierra Denali got the qudrasteer added.
As far a differences from a Sierra, Stock LQ4 6.0L, leather seats, wheels. Stuff like that.
Old May 13, 2011 | 05:39 PM
  #37
Tombstone's Avatar
Originally Posted by AndysC3
thanks
thank you
Old May 13, 2011 | 05:53 PM
  #38
chevyboy.520's Avatar
So when are you going to the track?
Old May 13, 2011 | 06:00 PM
  #39
smokeshow's Avatar
Mod with training wheels
Looks like its coming together
Old May 13, 2011 | 06:05 PM
  #40
AndysC3's Avatar
Originally Posted by Tombstone
thank you
no problem
Tomorrow night is open test-n-tune @ SIR so Im going to try and make it out. hoping for a 14.6@93 but with the heat it'll probably be a 14.8
Thanks. Still have a lot of work left to do.
