C3 build
Old Jun 24, 2012 | 12:29 PM
  #341
ak2007r6's Avatar
I would think shifting higher would allow you to keep the RPM's higher and loose less boost and power after each shift, especially with the converter you have
Old Jun 24, 2012 | 12:39 PM
  #342
milkey57's Avatar
Me personally I would probably shift a 6500. Thats a cam with a decent amount of lift, then add boost on top of it, thats a lot of stress on youre valve train. If you go to a 3.85ish pulley you should be able to make the same boost at a lower rpm. Thats just my thought though..But if you have light valves and good springs with a decent amount of seat pressure you should be able to shift at higher rpms.
Old Jun 24, 2012 | 12:43 PM
  #343
ak2007r6's Avatar
Just re read that, ya 6900 seems pretty up there. I would start at 6500 and see where that puts you. 6500 is where we are going to start after it's all put back together with my truck.
Old Jun 24, 2012 | 01:43 PM
  #344
AndysC3's Avatar
yea, would it be worth swapping the cam to the one pat g spec'd? get a little more down low when out of boost. the heads are WCCH heads, use Patriot duel springs.
Old Jun 24, 2012 | 02:52 PM
  #345
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Valve control wise the change in cam wont make a difference. You might want to swap to the smaller cam though to get more low and mid range since the procharger will carry the power on up top. I would get the procharger running great first, a new cam would be one of my last mods. That converter will probably need to be tightened up a bit with the boost.
Old Jun 24, 2012 | 02:59 PM
  #346
AndysC3's Avatar
its the one Chris recommended when I first told him about going with the procharger. If it doesn't work I may have it tightened up a bit
Old Jun 27, 2012 | 07:18 PM
  #347
Bloody-mustang's Avatar
This thing is sick bro!! Awesome build
Old Jun 27, 2012 | 07:33 PM
  #348
AndysC3's Avatar
Thanks, Should be even better in about a month or two.
Old Jun 28, 2012 | 08:27 PM
  #349
You should just put a kit on that thing and have some
Old Jun 28, 2012 | 09:04 PM
  #350
AndysC3's Avatar
Working on it. Will hopefully have the Procharger on by August.
