Budget Build Thread - Help
Old May 18, 2013 | 11:39 PM
  #101
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by 03 BLKTAHOE
Well I didnt really get to enjoy my boosted truck long. It was running like crap so my mechanic came over and I found out that it has "crank shaft end play" basically it could be the crank or the bearing or both so im thinking the best route is to look for short block.
I have a few question wheres a good place to get a short block?
Also could I get a 6.0 short block and just throw my 862 heads on and just get it tuned but keep the same computer?
I would not recomend throwing the 862 heads on a 6.0 for a few reasons. The first being compression ratio will be high.
Second the intake valves on those head are not as large as the ones that come on the original 6.0 head.
Your Basicaly going to spend more money makeing it work then you really need to.
Just get a long block LQ4 from 2001-up and be done with it.
Old May 19, 2013 | 11:02 AM
  #102
03 BLKTAHOE's Avatar
Thanks 1fastbrick I'll start looking for an LQ4. Will my existing computer work and will I just need a tune?
Does anybody know what the compression ratio be if I run ls9 head gaskets on an LQ4 with the stock heads? I want to run my turbo still...haha
Thanks
Old May 19, 2013 | 11:27 AM
  #103
If am reading right 9.4:1 is the compression ratio which is perfect for the turbo. now I just need to figure outif I need computer Or could I just use my 5.3 liter?
Old May 19, 2013 | 01:39 PM
  #104
1FastBrick's Avatar
Thanks
Yes, you can re-use your computer but it will need to be re-flashed for the new engine.
Yes the compression ratio is close to 9.5:1 on a stock LQ4.
Not sure how the LS9 gaskets will affect the ratio. Probally minimal at best.
Old May 19, 2013 | 03:01 PM
  #105
Mobile: Buy Spartan/ATK Engines Spartan Remanufactured Chevy Engine DCTF at Advance Auto Parts
Im thinking about this, I'll just swap everything over from my 5.3.
Can a reflash be down by a tuner or is that something the dealer does?
Old May 21, 2013 | 04:09 PM
  #106
If anybody can help im not sure how to figure out compression ratio.
I plan on buying this 6.0 and installing Ls9 head gaskets, 862 heads with head studs. What would be my compression ratio be?
I want ti put my turbo on so im wanting to hopefully be around the stock compression of 9.5:1.
ATK High Performance Chevy LQ4 6.0L Short Blocks SP19 - Mobile SummitRacing.com
Old May 21, 2013 | 10:02 PM
  #107
Engine Compression Ratio (CR) Calculator
If I calculated right I came up with 10.8747. I hope im wrong thats to high for boost right? Can I do anything to this heads to lower the compression?
Old May 21, 2013 | 10:24 PM
  #108
oakley6575's Avatar
Yea I got 10.76:1. Your problem is the heads. The 61cc combustion chamber is tiny. If you went with 317 heads, which are proven to be perfect for boosted applications, you could lower that compression down to 9.55:1.
Old May 21, 2013 | 10:30 PM
  #109
Yea Im thinking the same thing just got to find a set for cheap. My last question would be can I use my push rods from my 5.3 for the 6.0?
Thanks
Old May 21, 2013 | 11:33 PM
  #110
1FastBrick's Avatar
Thanks
The push rods are all the same, so yes. but if you're sticking a cam in it, get some aftermarket ones.
GXPJAY
Feb 13, 2022 08:15 AM
Blue03sss
Mar 7, 2019 05:06 PM
USMCvet0311
Aug 14, 2015 10:28 PM
Deceptarado
Jul 8, 2015 05:24 PM
ALynch
Jul 6, 2015 09:49 AM
