Budget Build Thread - Help
#93
I'm ordering my tune tomorrow and was wondering how you guys keep from going lean or to rich? Will it be in the tune? I need to get a wideband gauge and I found one that has several failsafe in it that you set like pulling timing or a setting for a boost level. This one works with Efi live but im getting Hptuners so I need to find another one or if you guys got any ideas?
AEM Performance Electronics Wideband Air Fuel Failsafe Gauge - Wideband O2 UEGO, Water/Methanol, Stand Alone Engine Management, Piggyback F/IC, Tru Boost Controller, Gauges, Automotive Performance Electronics
#94
I need some help im trying to install my AEM wideband but I can't figure out where to connect the white wire. I did a little research and can across this thread below that says connect it to the IEO#1 but I dont know what that means can some one please help? Thanks
To log in HPtuners, Once your wideband is installed, Power Ground..etc.*Hook the white wire into IEO #1 (top*pin) The Blue is un used. Open VCM Scanner, Click on Table Display, At the the bottum Right click on "IEO Input #1" Click Insert, open Wideband 02, Scroll down to "wideband 02-AEM, Doubble click then save config and your done.*That will get you up and running.. tuning with
#96
#97
Racetronix - need some help I bought a aeromotive stealth 340 part number 11169 from Summit Racing but my mechanic sad that I cannot put a pump inside the sending unit I need to buy the whole unit as one. Im going to return the pump and would like to get the right one could somebody give me a part number to one that will work? Im not sure also on center flow, outer flow. etc.. they said they have 3 other Aeromotives but not sure on center flow side flow etc could some tell me which one I have.
I found this one if it would work but I would have to order and wait for it in the mail.
#99
Well I didnt really get to enjoy my boosted truck long. It was running like crap so my mechanic came over and I found out that it has "crank shaft end play" basically it could be the crank or the bearing or both so im thinking the best route is to look for short block.
I have a few question wheres a good place to get a short block?
Also could I get a 6.0 short block and just throw my 862 heads on and just get it tuned but keep the same computer?
