Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
Old Aug 21, 2010 | 12:11 PM
  #231
custm2500's Avatar
Ph.D. in HUBRIS
What does the dash weigh? Once I get a different daily driver I am going to pull mine and either gut it or put in a sheet metal dash. Wondering how much it weighs.
Also the cog drive you have to be very carefull with because there is no room for error. With a surp belt it will slip if you have a backfire or get off the throttle, with a cog it can't. You just have to be carefully because the motor won't make up for any mistakes.
Old Aug 21, 2010 | 03:02 PM
  #232
blown02408's Avatar
02 w/ lowest mileage 2800
An ATI superpulley is a good idea with a cog drive, it will allow the supercharger to free wheel if you let off abruptly.
Old Aug 21, 2010 | 04:08 PM
  #233
custm2500's Avatar
Ph.D. in HUBRIS
Good info. Didn't know such a thing existed.
Old Aug 22, 2010 | 02:08 AM
  #234
Blown06's Avatar
8 Second Truck Club
I'm not overly worried about such issues. It's not like I have a manual trans and I'm pushing in the clutch at the end of a full throttle run or a shift. With an auto the motor comes down a lot smoother than with a clutch disengaging. Two BOV's and it should workout pretty good. That ATI super pulley is super $$$. We'll see if I have any problems first. Most cog horror stories that you hear about are the result from two problems, poor pulley alignment and flexing brackets. I have plans to fix both before they happen.
Old Aug 22, 2010 | 07:01 AM
  #235
blown02408's Avatar
Yeah I think you'll be fine too. The ATI super pulley is expensive about equal to 5 belts.
Old Aug 22, 2010 | 09:49 AM
  #236
custm2500's Avatar
Ph.D. in HUBRIS
The cost of belts wouldn't be my concern. The cost of a SC or motor is what I would be concerned about. Again you shouldn't have any issues but you just have to remember there is no fail safe besides your self.
Old Aug 23, 2010 | 02:22 AM
  #237
Blown06's Avatar
8 Second Truck Club
I'm gonna be honest, I'm really not sure what it is exactly your talking about.
Old Aug 23, 2010 | 02:24 AM
  #238
Blown06's Avatar
8 Second Truck Club
Damn, I was just reading your sig..............I want more details. Sounds like a serious setup. How much power/boost does it make, any track times?
Old Aug 24, 2010 | 06:42 PM
  #239
custm2500's Avatar
Ph.D. in HUBRIS
If you have a backfire or if you any other issue the cog belt won't slip and the backfire will be compounded by boost into the motor. I have no first hand experiance but I have seen it talked about few times.
Do you have a clue on the weight of the dash?
Old Aug 24, 2010 | 09:25 PM
  #240
Blown06's Avatar
8 Second Truck Club
No I don't, but it really isn't that heavy. It's mostly plastic.
