Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
Old Apr 17, 2015 | 09:53 AM
  #1891
George C....'s Avatar
Formerly ScreamingL
Originally Posted by Blown06
It's not gonna happen any time soon. There is no doubt in my mind I can make the procharger thing work. How many passes where made with any turbo truck before it ran 8's? It took 35 passes to run 8's procharged.
I won't need to do the turbo thing to stay on that list.
I really had the thing goofed up last year and it still ran good. There were a lot of things that where happening that should not have been happening. It'll run 8.50's consistantly with a janky motor. If I could get another job like I had a couple years ago and money was like water........peoples heads would roll.
Crema went 8s first time out with fresh build
Now what are you gonna do about the crank flexing and wiping thrust out? Are you gonna build a motor that has center weight cranks with crank support so flexing is kept to minimal?
A blower setup as you know isnt same beast as a turbo motor...you need twice or three times the internals on a big blower setup then would turbo
Blowers are fun to play with but not for everyone to go out racing with.....how long before you go crank driven procharger?
There's a jeep srt8 with a crank driven in the radial series
Old Apr 18, 2015 | 12:52 AM
  #1892
Blown06's Avatar
8 Second Truck Club
What thrust issues are you referring to? I don't have any thrust bearing issues. The crank does flex, but the bearings really looked pretty good for how much the crank is moving around. I don't see that issue getting any worse than it is, and it is working fine.
I'm on the fence regarding the gear drive. I personally like the belt. My opinion is that belt driven stuff is more reliable when spinning the **** out of these things. Just my opinion.
The next set up will have an f3 transmission housing and brackets though I'll say that. Whether I run the -121 or x-12a will depend on how big the next motor is.
When work picks back up to where it was, the plan is to do a -5 all pro headed deal on a dart tall deck somewhere around 460". If I can get that motor built, I'll do the f3-121. On methanol I don't think 2000+ horsepower would be an issue.
Old Apr 18, 2015 | 12:53 AM
  #1893
Blown06's Avatar
8 Second Truck Club
What industry is that?
oil/gas
Old May 6, 2015 | 12:25 AM
  #1894
Blown06's Avatar
8 Second Truck Club
I changed my mind and decided to whack off the front frame horns and replace with CM tube. Here is where I'm at so far.
Some pics before I started:
Some pics of the bracing:
Some pics after the cut:
Old May 6, 2015 | 12:29 AM
  #1895
Blown06's Avatar
8 Second Truck Club
This mod should be worth about 35-40 lbs off the truck in front of the front axle centerline.
That should be a huge benefit in getting the front/rear % improved.
Old May 8, 2015 | 06:28 AM
  #1896
Fukkn'Poof's Avatar
Where or how can i find a 4 link like yours?
Old May 9, 2015 | 12:16 AM
  #1897
Blown06's Avatar
8 Second Truck Club
It was all custom built.
Old May 22, 2015 | 01:33 AM
  #1898
Blown06's Avatar
8 Second Truck Club
Got the front sub frame all fabbed up. Just need to weld it out. I think it turned out pretty decent.
Old May 22, 2015 | 01:35 AM
  #1899
Blown06's Avatar
8 Second Truck Club
I weighed what was left of the stock frame horns and they were 45 lbs.
I weighed the fabricated piece you see above and it came in at 10 lbs.
So total weight savings is another 35+lbs.........in front of the front axle center line. HUGE!
Old May 22, 2015 | 12:11 PM
  #1900
GM1697's Avatar
Looks good, lets see it on the truck!
