Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
#1802
not sure if you saw where i had stated but
swap to larger tungsten
set machine to about 160 amps
use larger cup
pulse from bottom to top
torch about 10-15 degree angle
pulse is where youre on and off the pedal.....you go 100% then back off to about 40% move torch little go 100% again then back off to about 40% then move torch little go 100% then back off to about 40% and etc
try to give yourself a 60% overlap to keep the puddles tight so youre only going to be moving about 40% of a puddle which in this case is hair over 1/16 of inch
before making a pass use a steel wire brush and brush the area youre gonna weld
use larger cup
#1805
I guess I'm just a bit worried by your comment that I may have compromised the frame rail by going to slow (too much heat).
Seriously, I'll cut this **** out and weld in a new 3/16 section of frame rail if I have fucked it up. Not really something I want to chance.
#1809
#1810
