Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
#1782
if you need pointers message me and ill walk you thru otherwise you can say **** you to me and ill sit back
#1784
way to much heat not enough penetration, no control of filler, alot of tear points
also no wrap around on the ends
small enough tig cup and enough sick out will allow for welding of inside for a few inches
theres no lateral strength with no inside welding...
it all can be fixed
it all can be fixed
#1787
more torch and filler control, proper heat has a uniform heat ring sightly past the weld joint, to much heat past this zone can fatigue the metal.
amperage, torch angle, tungsten point, tungsten stick out, argon CFM all play roles in Tig welding
can also tell all of this by the weld puddle, alot of gray area is too much heat and alot of times to much argon CFM
mild steel can still show alot of colors when welded off
#1790
it all can be fixed
it all can be fixed
