Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
Old Mar 24, 2015 | 09:04 AM
  #1781
sprayedenali's Avatar
looks great!! i do believe ill be copying you!
Old Mar 24, 2015 | 10:26 AM
  #1782
George C....'s Avatar
Formerly ScreamingL
Originally Posted by Blown06
Here are some pics of the final brackets welded in. I'm gonna weld on a back strap as well and that will finalize the front suspension mods. What do you think?
please go back over those welds, as those arent as strong as you would like them
if you need pointers message me and ill walk you thru otherwise you can say **** you to me and ill sit back
Old Mar 24, 2015 | 11:26 AM
  #1783
care to elaborate on whats wrong with them George?
Old Mar 24, 2015 | 11:31 AM
  #1784
Formerly ScreamingL
way to much heat not enough penetration, no control of filler, alot of tear points
also no wrap around on the ends
small enough tig cup and enough sick out will allow for welding of inside for a few inches
theres no lateral strength with no inside welding...
it all can be fixed
Old Mar 24, 2015 | 12:59 PM
  #1785
GM1697's Avatar
I was wondering if an inside pass would be possible or if it would be to tight to get in there...
Old Mar 24, 2015 | 02:07 PM
  #1786
how would you achieve better penetration AND less heat?
Old Mar 24, 2015 | 02:13 PM
  #1787
Formerly ScreamingL
more torch and filler control, proper heat has a uniform heat ring sightly past the weld joint, to much heat past this zone can fatigue the metal.
amperage, torch angle, tungsten point, tungsten stick out, argon CFM all play roles in Tig welding
can also tell all of this by the weld puddle, alot of gray area is too much heat and alot of times to much argon CFM
mild steel can still show alot of colors when welded off
Old Mar 24, 2015 | 04:40 PM
  #1788
Funkster's Avatar
12 Second Club
So is your passenger side airbag still hiding under the cover or did you find a way to mount the cover back in the dash without the Airbag in it?
Old Mar 24, 2015 | 10:26 PM
  #1789
oakley6575's Avatar
Old Mar 25, 2015 | 12:36 AM
  #1790
1FastBrick's Avatar
Custm2500's Rude Friend
it all can be fixed
Amen!!! Thanks for point that out.
