Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
#1621
Yes but from what I understand an engine on methanol runs much cooler then one on pump gas or race fuel. That is why I asked the question if it helps keep the engine cooler and you wouldn't need all the cooling modifications.
#1625
I'm hoping that I can at least get one test session in before the end of the year. Engine guy wants to re dyno it on an engine dyno again, but this time with the blower on it. So that should be fun.
#1626
Just a heads up, I'm gonna be selling the following components as a package deal. I'll post a classified with pics later.
Moser converted 5-lug hubs and rotors
Belltech 2" drop springs with buckets
Single adjustable QA-1's
Calipers ground to fit a 15" bogart
Thinking I'm gonna ask $500 for it picked up.
#1630
Engine guy is moving right along. Heads are all set up for cooling and welded up. I think they are at greg goods for a final freshen. 1/2" head stud conversion is done on the block and the pistons are done.
Once the heads get back from greg's, everything will go to polydyne and then it should be as simple as a hone and throw back together.
I do hope I see some power improvements......Jesus busted off an 8.80 and other guy from the valley went like 8.79 I believe. Then Spike reset the record with his twin turbo entry at 8.05. Hoping I can land somewhere in the middle.
