Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
Old Apr 14, 2014 | 05:11 PM
  #1371
black00chev's Avatar
Slowest turbo build ever!
Like Atomic said, looks to me like its either coming from the line or the top corner of the HX itself.
Old Apr 14, 2014 | 11:11 PM
  #1372
Blown06's Avatar
8 Second Truck Club
Originally Posted by silver-mod-o
That doesn't look healthy, whatever it is
-how did you like Evadale? If I'd have known you were out there I would have stopped by.
Evadale is awesome, closer than SAR, less people than RPR and much better track than LSMP.
Old Apr 14, 2014 | 11:13 PM
  #1373
Blown06's Avatar
8 Second Truck Club
Did some testing tonight. Radiator is not cracked anywhere. Cooling system will hold 22 psi forever. Did a leak down, results as follows:
1: 5%
8: 13%
7: 20%
2: 9%
6: 23%
5: 17%
4: 17%
3: 18%
Leakdown was done cold. I'll see what the engine builder says tomorrow.
Old Apr 15, 2014 | 06:53 AM
  #1374
Atomic's Avatar
I have a gauge for that
Put 40psi to the coolant system. What base pressure did you use for leakdown? How do the plugs look?
Old Apr 15, 2014 | 07:01 AM
  #1375
stennyboy's Avatar
how much psi is your cap? 22? Do like atomic said and pump it up a little tighter.
Old Apr 15, 2014 | 08:41 AM
  #1376
Atomic's Avatar
I dont think you are lifting the head, because if you were it is several hundred psi and like I said the engine would be broken by now. Do you have an A2W intercooler? Maybe your intercooler has an internal leak and is pressurizing the hex.
Old Apr 15, 2014 | 09:11 AM
  #1377
smokeshow's Avatar
Mod with training wheels
Not everyone breaks engines as fast as you, Richard
Old Apr 15, 2014 | 09:18 AM
  #1378
Atomic's Avatar
If you arent breaking **** you arent trying hard enough!
Old Apr 15, 2014 | 09:53 AM
  #1379
silver-mod-o's Avatar
Hunt&Fisherator
Leak down numbers can be misleading also at times. All it takes it one shred of carbon or anything between the valve and seat to skew that in a big way. But I do agree with consulting the builder. I think what Atomic is saying is very plausible as well.
Old Apr 15, 2014 | 10:56 PM
  #1380
Blown06's Avatar
8 Second Truck Club
Putting 40 psi in the radiator will show nothing that 20 psi won't. The bottom line is that it is not cracked as suspected.
I'm not sure how pushing the heads would guarantee that the motor should be broke???
It's obviously pushing water from the heads lifting. The overflow system I had in place was overwhelmed by the volume and pressure that needed to escape the radiator, hence it blowing by the cap.
Couple more decisions and I'll have a plan to move forward.
