Blown 408(literally)
Old Sep 18, 2010 | 10:03 PM
  #181
Atomic's Avatar
I have a gauge for that
Why the cheater instead of the true slick?
Old Sep 19, 2010 | 12:21 AM
  #182
brent5631's Avatar
You can drive it to the track.
Old Sep 19, 2010 | 12:28 AM
  #183
2004SSS's Avatar
with 4:56 and your power you may go into 4th gear with a 28" or smaller tire.
with 4.10's and a 305/45/18 ( little more than 28" ) i wan getting close to 4th with the 4l65e making a bit more power trapping in the 121 ish range
Old Sep 19, 2010 | 07:21 AM
  #184
custm2500's Avatar
Ph.D. in HUBRIS
Full slick costs more, needs a bigger burnout(less life), and you don't need a full slick.
Old Sep 19, 2010 | 07:48 AM
  #185
Atomic's Avatar
I was wanting to go with a 30" tall tire so I didnt run out of gear too soon, and the bigger the sidewall, the more flex and more traction, right?
Old Sep 19, 2010 | 09:27 AM
  #186
custm2500's Avatar
Ph.D. in HUBRIS
You will probably want a stiff side wall with such a heavy truck. Sidewall flex isn't as much a part of the game any more. It comes into play but the 30" will give you more traction then a 28 because of the bigger outside diameter.
Old Sep 19, 2010 | 10:22 AM
  #187
Atomic's Avatar
Well I have to use a 16" wheel for the rear because of the brakes, and the only 30" tall 16" rim is 14" wide Any other brands you recommend?
Old Sep 19, 2010 | 10:46 AM
  #188
custm2500's Avatar
Ph.D. in HUBRIS
I was looking and you might have to go with a full drag slick. They have a 33-10.5-16 so you might not be able to stay in a DOT slick but that isn't the end of the world.
Old Sep 19, 2010 | 10:50 AM
  #189
Atomic's Avatar
I am prepared to swap them at the track anyway
Old Sep 19, 2010 | 11:58 AM
  #190
double047's Avatar
14 Second Truck Club
True dedication, I like to see that!
