BlackGMC build take 3 - Supercharger Time
Old Jun 28, 2015 | 07:05 PM
  #41
BlackGMC's Avatar
Resident Retard
Here is how i plan to feed and return fuel also i will be hooking my FPR gauge right at the output of the rail. That is a 120* hose end on the left. I might need a 160*
Originally Posted by SCChevy
Air Cleaner looks almost as big as the high ram in the parts picture.
No it is really that big. Kinda cartoonish looking.
Old Jun 28, 2015 | 07:20 PM
  #42
TXsilverado's Avatar
looks like progress to me.
Old Jun 28, 2015 | 07:21 PM
  #43
silver-mod-o's Avatar
Hunt&Fisherator
All those AN fittings seem like overkill at the time but damn don't they make it nice taking things apart and putting it back together I fully intend on running everything I can in With AN fittings and hard lines/compression fittings if I ever build another one. So much cleaner, fewer leaks (none if done right) and it usually lasts a lot longer than regular rubber hose.
Old Jun 28, 2015 | 07:29 PM
  #44
BlackGMC's Avatar
Resident Retard
Yep. It has been slow due to the heat and lack of motivation.
They are expensive, a PIA and expensive but IMO they are worth it to never have to worry about leaks.
Old Jun 28, 2015 | 08:05 PM
  #45
03sierraslt's Avatar
Looks similar to mine, -8an 90 into pass rail and -6an 120 out of drivers rail to regulator. The fragola -6orb/-8an fitting can be drilled out to open it to -8 the whole way FYI.
Old Jun 28, 2015 | 08:45 PM
  #46
Atomic's Avatar
I have a gauge for that
Good place to ask I suppose, when you are installing an aftermarket crank pulley that uses a woodruff key with the crank, do you insert the key into the crank and press the pulley on so the key slides down the pulley, put it in the pulley then press it on the crank, or tap it in at the end?
Old Jun 28, 2015 | 09:47 PM
  #47
Jetn3's Avatar
What brand and size air filter was on your turbo set up? Are you gonna run same filter with the SC? Any FI setup is a good setup.
Old Jun 28, 2015 | 10:57 PM
  #48
BlackGMC's Avatar
Resident Retard
Yep i plan to use the same filter
here it is
http://www.summitracing.com/parts/aao-ab-f10-r60ps
Old Jun 28, 2015 | 11:08 PM
  #49
George C....'s Avatar
Formerly ScreamingL
ehh...my Silverado never felt fast. its best pass was 7.42 at 94mph with a 1.68 60' (150 shot).
my s10 feels the same. its best pass was 6.80@101 with a 1.46 60' (motor)
that's .62 faster in the 1/8 and my *** cant tell the difference. i don't trust butt dynos.
i know what you mean, ever since ive gone 8.6 everything else i drive feels like a turd
Old Jun 29, 2015 | 12:55 AM
  #50
SCChevy's Avatar
I work with big equipment. Much of it uses keyed shafts. I have always found it easier to put the key on the shaft and then press the pulley over it.
