BlackGMC build take 3 - Supercharger Time
#133
The bottom line is I do have the blower maxed out right now. Better heads, and a cam that is a little more tailored to boost would definitely add the power... but it has its limit. The 2300 will do everything I have accomplished and do it without even breaking a sweat.
at 14PSI with the 2300 it will run like an animal! And if he wants more boost its only a pulley away.
I know the concern is that a Larger blower can see more laggy, but that difference wont be noticable here. That comes into play when you have a much larger blower spinning low RPM's. Now if he was targeting 6PSI I would venture a guess that the 1900 is more responsive at that RPM level. Basically the faster you spin them, the more respnisive these blowers become. At a certain point, just as with anything else, there is a law of diminishing returns. Meanwhile you deal with extra heat moving out of the blowers efficiency range. At 14PSI his 2300 is going to be a light switch. He will hit 5PSI crossing an intersection when his foot bounces a little...
I have mine welded as well.
#134
