BlackGMC build take 2 - Turbo Time
Old Aug 4, 2014 | 07:05 PM
  #791
oakley6575's Avatar
I bitched at dirty dingo for my idler pulley relocation bracket and he seemed like a good guy. Sent me a better designed bracket for free. But if you found a stronger design, probably would be better to wait it out. How come you couldn't find any stock brackets off of an F body?
Wait, wait, wait. You plan on running 20psi through your truck?
Old Aug 4, 2014 | 07:14 PM
  #792
BlackGMC's Avatar
Resident Retard
Stock fbody brackets would not line up with the ac compressor, the harmonic balancer and the 2010 camaro pump. Also since i have an iron block it only uses 2 bolts to attach the alternator, aluminum blocks have a 3 bolt hole. Sooooo long story short the stock fbody brackets would not work.
Old Aug 4, 2014 | 07:24 PM
  #793
oakley6575's Avatar
Gottcha
Old Aug 4, 2014 | 10:49 PM
  #794
BlackGMC's Avatar
Resident Retard
I finally got a tracking number for the bracket. I should be back on the road thursday/friday. Then back to favorite activity, tuning
Old Aug 4, 2014 | 10:50 PM
  #795
GMCtrk's Avatar
When your meth comes on under boost is it a seamless transition or can you tell?
Old Aug 4, 2014 | 10:51 PM
  #796
BlackGMC's Avatar
Resident Retard
I have only made like 1 pull with the meth on. So i really cant comment since it pegged the wideband dead rich.
My old kit is was pretty seamless but the exhaust note changed.
Old Aug 4, 2014 | 10:56 PM
  #797
ecir45's Avatar
Like what this guy on ebay is offering for brackets.
LS1 LS3 Crate Engine Narrow Bay Conversion Bracket 3 8 Billet Aluminum | eBay
LQ LS1 LS Low Mount Alternator Bracket Swap Power Steering Delete Bracket | eBay
Main | LS Brackets
Old Aug 4, 2014 | 11:02 PM
  #798
BlackGMC's Avatar
Resident Retard
I like that one piece bracket. Looks pretty solid.
Old Aug 6, 2014 | 09:00 PM
  #799
turbo.trex's Avatar
Nice setup .... How do you like that Holley intake
Old Aug 6, 2014 | 09:12 PM
  #800
BlackGMC's Avatar
Resident Retard
Thanks. I changed a lot so it is hard to gauge how the intake is performing plus i have not pushed it at all yet. I have noticed 2 things about that intake.
1. The truck pulls more vacuum cruising down the highway. I take this to mean it is more efficient than my previous intake at low RPMs. Also MPG has gone up compared to when i had my old 4.10s.
2. Heatsoak.... I have not noticed an issue with high iats even in 100+ temps outside. The intake itself gets insanely hot on the outside. I went for a test drive about 20-30min. When i was done i popped the hood to work on some stuff. I had to put down a towel on the intake to keep from burning myself. Even hours later it was hot. But like i said no real impact to IATs.
