ak2007r6 Build Thread
Old Mar 22, 2012 | 04:21 PM
  #271
Atomic's Avatar
I have a gauge for that
No. When you flip your switch you are grounding pin 85. 86 is connected to ground as well, so there is no voltage drop. Without a voltage drop (difference) current doesnt flow and nothing happens. So your "ground" by your switch should actually be a power OR the 86 pins should go to power; it doesnt matter which.
Also, fusing that link is not necessary since it takes far less than 0.5amps to trigger the relay, so in total you are probably looking at a 1a draw for all three.
A fuse needs to be on the 87-30 path.
Old Mar 22, 2012 | 04:35 PM
  #272
ak2007r6's Avatar
Ok I see the bonehead mistake and grounding two of the points
So something like this.
Old Mar 22, 2012 | 04:36 PM
  #273
ak2007r6's Avatar
Or should the in line fuses on the 87 to 30 path be after the relay?
Old Mar 22, 2012 | 04:40 PM
  #274
Atomic's Avatar
It really shouldnt matter. Im not sure what those circuits are rated for current wise, but most automotive relays are 30a. If one of them draws more than that then you need a bigger relay (or run several in parallel). If at any point the current in that path exceeds the fuse the fuse should blow so the current is then 0. Where that happens doesnt matter.
Old Mar 22, 2012 | 04:53 PM
  #275
ak2007r6's Avatar
Gotcha. Thanks for all the help, now to just find what wires going into the fuse box are the ones I need.
Also if it's a lighted switch just run the other wire to an ACC wire under the dash or any wire that is only hot when key is on?
Old Mar 22, 2012 | 05:26 PM
  #276
DR132's Avatar
Yeah if you want a lighted switch i would just run the light wire to something that's on with the ignition.
Old Mar 22, 2012 | 05:31 PM
  #277
ak2007r6's Avatar
Awesome. Well you learn something everyday! Will add this to my list of things to do when home.
Old Mar 22, 2012 | 06:05 PM
  #278
RacinRust's Avatar
This 2011 electrical manual is over 700 pages. Trying to figure out how to post so you can download. Any suggestions ?
Old Mar 22, 2012 | 06:10 PM
  #279
ak2007r6's Avatar
I have a dropbox account I can PM you a link to and you can drag and drop it there.
  #280
DR132's Avatar
Find a scanner and just put up the applicable pages?
