6.0 Turbo build
#76
Got the regulator in and fired up the truck and no leaks, well fuel leaks anyways....
Now the an adapters screwed into the radiator are leaking so i guess ill have to chase down that problem now....
#78
Yup, the passenger side actually uses the stock hose from the valve cover to the TB and for the drivers side I drilled out the hole in the PCV valve thing so its not tiny any more and ran 3/8 hose to the can. I'd think that should be plenty. I you wanted to you can run a hose from the top of the can to your supercharger inlet so you dont get a smell, I know turbo guys do that but I dont know about procharger guys
