6.0 Stick Shift Tahoe (NV4500)
Old Jan 15, 2022 | 09:27 AM
  #601
arthursc2's Avatar
They can't be, hence the 7th injector tuning "solution"
Usually on a Hobbs switch or similar so part throttle boost is all MAF correction (if you're lucky) and WOT is le 7th boi puking fuel and being controlled by a piggyback or the URD control box: which is a piggyback for 1 injector lol
Its a dumb solution
Old Jan 15, 2022 | 06:56 PM
  #602
dantheman1540's Avatar
HPT now supports those 2nd gen tacos so it might be different now.
Old Jan 15, 2022 | 08:57 PM
  #603
_zebra's Avatar
makes children cry
Originally Posted by dantheman1540
I genuinely find meth to be sketchy which is why I don’t fuhq wit dat, there’s just better solutions to fueling IMO.
URD makes some nice stuff like their short throw shifter which just changes the pivot point instead of the entire shifter and keeps the factory vibration damper which helps a ton. There’s just not much you can do to engines with nearly no power potential.
sounds like you're just being a *****! meth is fine when properly set up & accounted for in the tune (more safely used only for IAT reduction as opposed to octane booster for additional timing). but to really make it work right with a PD blower, it's more involved than it usually worth - requiring a direct port setup to actually be effective.
Old Jan 16, 2022 | 07:50 AM
  #604
I could get down with using meth to keep IATs in check but as a primary fuel source no thanks. There’s a reason people don’t do much with the 90s toilet bowl injection stuff.
Old Jan 16, 2022 | 11:11 AM
  #605
arthursc2's Avatar
toilet bowl injection ahahahahahahahahaha
got damn that nearly made me choke lmao
Old Jan 16, 2022 | 02:52 PM
  #606
_zebra's Avatar
makes children cry
primary fuel source? you talking an alky motor or E85? two different beasts.
Old Jan 17, 2022 | 06:55 AM
  #607
The 7th injector that people use on the Tacomas is used for most of the in boost fueling since the stock injectors can only do so much and can't really be replaced easily. So it's more than just a mild octane boost and IAT dropper.
Old Jan 17, 2022 | 11:39 AM
  #608
Anyone want to guess how much this thing weighs? I weighed it today with a full tank of gas, 150# of gear in the back but my self NOT included in the weight.
Old Jan 17, 2022 | 11:44 AM
  #609
shakenfake's Avatar
Shlumpt
5 Year Member
5700?
Old Jan 17, 2022 | 11:48 AM
  #610
Close but to high
