5.3/T-56 RCSB OBS Build
Old Jul 7, 2016 | 08:59 AM
jgh64pkup's Avatar
Default 5.3/T-56 RCSB OBS Build
I started this thread over at 67-72chevytrucks.com, heres the original thread. 5.3/4l80e RCSB build - The 1947 - Present Chevrolet & GMC Truck Message Board Network
Here's a quick rundown.
Originally Posted by jgh64pkup
My buddy bought this truck about 2 years ago. It Originally had a 4.3 and a 5 speed. That got swapped for a 468 and th400, then got swapped for a 5.3/4l60e. The last setup he had in it was a 6.0/4l80e with a on3 76mm. I recently aquired the roller in a trade. My plans are a cammed 5.3 on a 175 shot, decent built 4l80E with a 3600 stall edge converter.
On our way to TX2k15 in Houston
I bought a drag wheel setup and got the engine set in.
The engine is out of my car, Im switching to a big turbo setup in it.
Headers showed up yesterday. I got the paint stripped, v-bands welded on, and repainted with a few coats of vht.
Old Jul 7, 2016 | 09:03 AM
jgh64pkup's Avatar
Few more pics.
Did a little modifying to the core support to fit the radiator.
I rolled the truck out last night to clean the garage up. Driveshaft is in, fuel filter and lines are ran, now all I need to do is clean up the engine harness and graft it into the body harness.
My exhaust is done. Dual 3" into a Magnaflow x-pipe and Magnaflow race ovals.
Sure wish I had a lift.
Old Jul 7, 2016 | 09:04 AM
jgh64pkup's Avatar
And in its current state. I need to start on the wiring and get the cooling system wrapped up.
Not much of an update, but i did move it outside and get some better pictures after I installed the lights. I still need to adjust the headlights, theyre way off.
Old Jul 7, 2016 | 12:42 PM
matte99's Avatar
That's a good looking truck. It's nice to see someone going the nitrous route.
Old Jul 8, 2016 | 09:54 AM
jgh64pkup's Avatar
Thanks. The setup in my car went 7.4 @96 on a stock truck intake, and a junk fogger nozzle on a 150 shot. we tried bigger jets but it didnt change anything, so I'm not sure where it quit flowing. I think it should do a lot better on the 2 stage plate.
http://vid886.photobucket.com/albums...stangtrack.mp4
Old Jul 20, 2016 | 10:33 AM
jgh64pkup's Avatar
I finally got to drive the truck Sunday. It starts off in second and goes straight to 3rd. Im thinking the 1-2 shift solenoid is bad.
Old Aug 1, 2016 | 10:10 AM
jgh64pkup's Avatar
Got the shift solenoid changed and got the trans working. Then I decided to get rid of the 80e. I pulled everything and traded it for a t-56 swap. M12 t-56 out of a GTO, Monster Stage 4, and a B&M Ripper.
Old Aug 1, 2016 | 04:41 PM
hutch311's Avatar
I dig the build. Keep the updates coming!
Old Aug 3, 2016 | 09:53 AM
jgh64pkup's Avatar
Got the t56 in for mockup. The shifter clears the bench seat surprisingly.
It also clears the exhaust.
Old Aug 3, 2016 | 11:03 AM
matte99's Avatar
That's nice your exhaust worked with the t56 too.
