5.3 \ 72mm / 80e \ Ecsb build.....
Old Jul 20, 2014 | 10:33 AM
  #191
skolman91's Avatar
needs more booooost then..
Old Jul 20, 2014 | 01:45 PM
  #192
oakley6575's Avatar
With my turbo, I'd need to leave around 3500 or so to cut a sub 1.75 second sixty. Good thing I have a hydro booster sitting in the shop waiting to be put in.
What did the carrier bearing sound like when it let go?
Old Jul 20, 2014 | 07:57 PM
  #193
Chevy_King1500's Avatar
not sure, everything seemed fine.
when I turned off and headed to the ticket box I knew something didn't feel right, it was rubbing and vibrating. i was able to drive up onto the trailer tho!
Old Jul 21, 2014 | 10:08 AM
  #194
LowSilver's Avatar
I read through this thread on the weekend. Nice build! Also, seen you did the 3" coils, and it was sitting on the front bump stops. Thanks for the heads up! I ripped mine out after reading about it haha! rides a little softer now!
-Kenny
Old Jul 21, 2014 | 06:18 PM
  #195
-Kenny
pretty much needed when you drop it that low, check out the belltech bump stops (1.26" tall)
Old Jul 23, 2014 | 09:10 PM
  #196
Ordered a rear sway bar for the truck. I was getting a lot of movement at 70+mph on the interstate. hopefully it helps plant the truck to the road. and i hope it fits over my diff cover
going to the parts store tomorrow to pick up a few other things.
145 amp alternator
belt
idler pulley
carrier bearing
Should give me something to do over the weekend.
Old Jul 23, 2014 | 11:28 PM
  #197
oakley6575's Avatar
145 amp alternator
belt
idler pulley
carrier bearing
I didn't even think about it but I have a ton of bearings and stuff sitting around. I could have sent you a new koyo.
Are you running a 105 amp alt right now?
Old Jul 24, 2014 | 08:07 AM
  #198
skolman91's Avatar
145amp alt is well worth the money if you have alot of electronics or efans, good choice.. and good luck with the sway bar and rear cover, hope it fits..
Old Jul 24, 2014 | 11:27 AM
  #199
well if it doesn't, i will have one for sale
Old Jul 26, 2014 | 06:38 PM
  #200
pics of the breakage
