4.8 to 5.3
Old Apr 9, 2013 | 07:05 AM
  #21
outlawz2004's Avatar
Yeah, I talked to Charlie and he said to go over those spark plug wires, also going to check to make sure I didn't unplug something while installing other things. I suspect the plug wires though because like I said, I had to pull on them pretty good to get them off. Might have damaged one.
Old Apr 9, 2013 | 02:18 PM
  #22
Swapped the plug, the wire, the coil pack and still nada. Turned out to be a clogged fuel injector. Put one in from my 4.8L fuel rail and seems to be running pretty smooth even on the 4.8 tune.
Old May 8, 2013 | 07:22 AM
  #23
1customrides's Avatar
Registered User
Originally Posted by outlawz2004
I am almost completely done now, waiting on PCM that should be here tomorrow or Weds. I have to put in driveshaft, y pipe, battery. The worse part was all the wires. I labeled everything but there are a ton of grounds, and GM used every kind of clip so it takes a little looking to see how to open them. The grille and core support took longer than the engine, I forgot how alot of it went LOL. I wasn't working full days on it and taking my time, so if you bust your butt you could get it done fairly quick.
how much is that pcm tune from wheatly?
Old May 8, 2013 | 08:13 AM
  #24
I think he charges $275 now
Old May 10, 2013 | 12:01 PM
  #25
vipergtrdj's Avatar
I'm guessing the injectors were the same between the 4.8 and 5.3? I haven't looked at my 4.8injectors, or researched it.
Old May 10, 2013 | 06:54 PM
  #26
should be
Dan Neumann
11
Aug 7, 2022 09:06 AM
luis_bullz
Sep 8, 2015 03:08 AM
JordanH
Aug 8, 2015 07:59 PM
MS3Z
Jul 30, 2015 06:17 PM
06 4.8
Jul 15, 2015 07:17 PM
