370 build FINALLY getting started
Old Jul 25, 2008 | 09:23 AM
  #151
Hawk179's Avatar
Originally Posted by Wilde Racing
Ya, me neather....LMAO
Where you bored?
R
Old Jul 25, 2008 | 09:52 AM
  #152
Wilde Racing's Avatar
How do I change this text
Originally Posted by Rick@Synergy
Where you bored?
R
Some people believe using the old steam tube that uses all ports will help fight number 7 failures. Others think if some is good, more is better.
Old Jul 25, 2008 | 09:55 AM
  #153
Originally Posted by 427
We ran the tubes in the Motorola cup cars because if we put the back plug types in the #7 cylinder would have problems. It seemed to me with the testing we did that air pockets formed in the back of the head from the coolant boiling causing the engine to detonate on the back cylinders. Normally #7 would eat the piston or break the rod and #8 would show signs of trouble. These are just guesses on my part based on what the parts looked like broken!
Kurt
Old Jul 25, 2008 | 11:11 AM
  #154
zippy's Avatar
Looks interesting. You certainly might seen different results if it works out well during tuning.
Old Jul 25, 2008 | 09:55 PM
  #155
Hawk179's Avatar
Thats it.....-10an lines going in.
R
Old Jul 26, 2008 | 05:13 AM
  #156
stock48's Avatar
9 Second Truck Club
For what it's worth I had no steam tubes front or rear on my truck. When it took it's self apart #7 piston was still intact, and in good shape for running with a bent rod.
Old Jul 26, 2008 | 05:42 AM
  #157
Well not much to report for tonight. I got the water pump on, all the rockers, exhaust manifolds, and knock sensors in. All I need to do to the block is Flywheel, oil sensor, and prime... I did get the reverse apply pin in the 4l80, so the trans is ready to go....
Old Jul 28, 2008 | 09:04 AM
  #158
Default The Engine Runs!!!!
Well, the trans is in the engine is in. I fired her up for a few seconds last night, just need to tie up all the loose ends and fix my shift cable..
why did you remove the steam tubes? How do you get the air pockets out of the heads?
Old Jul 28, 2008 | 09:20 AM
  #159
stock48's Avatar
9 Second Truck Club
I just didn't think I needed it. How does it sound, any piston noise?
Old Jul 28, 2008 | 09:27 AM
  #160
Hawk179's Avatar
His motor slaps like two 12's in the back of the truck.
