2013 Avalanche 6.0 Swap
Old Mar 20, 2018 | 09:56 PM
  #31
mjcotroneo's Avatar
I had an ls9 cam in my escalade with 3:42's and a 3000k stall. it works well with a stall and a good tune. I used that cam with the stock 6.2 and the 408 I had as I planned on doing and lsa blower. I loved that cam but I decided to change it when I did the build I currently have.
I don't know who said 4k rpm but that is not accurate to say the least lol
The valve events of an ls9 cam are not favorable for a NA truck no matter how you look at them. It would feel like a slouch below 4K rpm.
Old Mar 21, 2018 | 11:45 PM
  #32
01FormulaTA's Avatar
Elite Engineering Catch Can installed today...
Stainless M8 Nuts and Bolts...
I need some Black Zip Ties...
Goodyear 3/8" Fuel Line...
Old Mar 30, 2018 | 10:50 PM
  #33
So I recently had the truck tuned, it runs pretty good now....some comparison videos below...
L96 6.0 TSP 212/218 .600 .600 50-75 WOT
LS3 6.2 Cam Motion 206/216 .553 .553 25-75 WOT
Old Mar 31, 2018 | 05:26 PM
  #34
SDjeff619's Avatar
Sounds damn good, picks up a goes.
Old Apr 1, 2018 | 01:37 AM
  #35
Thanks man! yah it moves out pretty good now!
Love your build btw...hopefully I can add some boost down the road
Old Apr 11, 2018 | 06:28 PM
  #36
well I decided im gonna add some boost sooner than later....so I ordered a TVS1900!....I would like to run 9-10# of boost...will I need Meth to run 10# on 93 octane??....now that I bought the blower im questioning the whole build...I still have my L96...should I use the lower compression Iron Block 6.0 for longevity or stick with the higher compression Aluminum LS3? My goal is a 600+ RWHP Daily Driver....
If I did use the 6.0 I would a most likely throw an LS9 cam in it...If I leave the LS3 Im just bolting on the blower and sticking with my original cam choice...
Would love to hear some opinions...
Old Apr 11, 2018 | 07:13 PM
  #37
FFDP's Avatar
The LS9 cam would be a bad choice in a heavy truck.
Don't get stuck on boost pressure, that's just silly. See what power it makes right out of the box and go from there if you ask me.
People are boosting factory Camaro's to pretty crazy power levels, I don't think you are going to have any problem with it being reliable on a good tune.
Old Apr 11, 2018 | 07:55 PM
  #38
Im sure there are better cams out there but from the ZR1 dyno graphs I have seen the LS9 cam has a nice fat torque curve with 10#'s of boost that would do well in a heavy truck...on a stock LS9 the LS9 cam makes 500+ ft-lbs from 2200-6500RPM....Im not necessarily stuck on boost pressure I just know the kit it is pullied for 6#'s stock which will be around a 120HP gain...10PSI should be closer to 180-200HP gain and get me closer to my goal....I would rather pulley it down from the get go than deal with running it out of the box getting it tuned then swapping pulleys and getting retuned etc....
Main questions aren't about cam selection....more so would there be a difference in reliability from a 9.7:1 compression vs 10.7:1 compression on 10#s??
would I need meth to run 10#'s on 93 octane?
Will the Flex Fuel Pump support 600rwhp with some ID725s?
Old Apr 12, 2018 | 11:41 PM
  #39
got some new wheels tonight...I wanted a light weight wheel and these popped up on Craigslist for a good deal...some 3 Piece CCWs Classic 5's...18x9 and 18x10...gonna run some Mickey Thompson 30"x12.00" which are equal to a 305/50R18...stock 275/55R20 are 31.9" tall so will only be a 1" drop from the tires and then I will also be installing the Tahoe PPV rear springs and removing the .5" spacer in the front so total drop with suspension changes and the new wheels and tires will be 1.5/2.75...fronts weigh 24lbs each and rears 25.2lbs each...tires weigh 36lbs each..should be a nice decrease in rotating weight...
Old Apr 13, 2018 | 12:57 PM
  #40
SDjeff619's Avatar
Those look sweet.
