2013 Avalanche 6.0 Swap
#41
Thanks! From what the seller told me these are the only set of CCWs for a GMT900 that CCW has ever built....I was so close to copying you with Cosmis wheels until these just popped up out of nowhere, I really wanted 20's but couldn't pass up the deal I got on these...$885 per wheel on CCWs website, I ended up paying less than the cost of of new set plus I got new tires in the deal
#47
I have a Stock 2012 Avalanche LTZ 5.3 4x4 with 373 gears. I would like to swap to a 6.0 or 6.2. A local guy has a L92 long block without intake, flex plate or ballencer, but I would go through it. Would a complete engine be better? I would like it to be basically stock as it is daily driver. Would also like AFM delete. What issues did you have during your swap? Besides getting a tune any other wiring issues or problems? Thanks for any advice.
#48
The swap is pretty straight forward. Your flex plate and Balancer will swap over from your 5.3. You will need to source an intake from either a 6.0 or 6.2 as your 5.3 intake will not fit. The L92 doesn't have AFM so you won't have delete it but I would at least drop the oil pan and clean it before you install the new motor. Also, I recommend changing out the motor mounts when you do the swap. I didn't really have any issues with the swap, it is all plug and play, including all the wiring. I did have to buy a new starter, the 6.0 and 6.2 starter is bigger than the 5.3 starter. You will need to get a tune for the new motor immediately after install, if you dont have anyone local plenty of guys on here can do a mail order tune for you.
#49
I really appreciate all the great info! If I do upgrade the cam lifters and timing chain but everything else is stock any suggestions on a cam or a company to make recommendations? Do you have an intake or anything left from your build for sale I can use? Great to get info from someone who has already completed the swap. Thanks again!
#50
