2009 Crew Cab - Stage III Build Begins
Old May 8, 2020 | 03:59 PM
  #101
vettelovralexand's Avatar
Originally Posted by Jeebalow
Hadn't seen this thread in a while. Seems like it's a blast. Very excited to hear that this thing is reliable and you would not hesitate to let you wife drive it. I am building a 370 and putting a 2.3L blower on (cam spec'd by vortec350ss I believe @deadpoolsilverado on IG) and that is exactly what I am going for!
What are the cam specs? What heads?
Old May 8, 2020 | 05:06 PM
  #102
Jeebalow's Avatar
Its a 222/236 on a 117. I have 243 heads that have been milled down 0.030" with 15cc dish diamond pistons. Was shooting for 10:1 ended up at 9.8 or 9.9 I need to verify the chamber size and deck clearance to get the final number.
Old May 8, 2020 | 06:06 PM
  #103
Any advance on the cam? Sounds like our setups will be pretty similar.
Old May 8, 2020 | 07:12 PM
  #104
Jeebalow's Avatar
3 degrees advance ICL at 114
I'll eventually turn the Blower up to 18,000 RPM. I'll have to make sure my fuel system can support what the blower will do. What do you have for a fuel system?
Old May 8, 2020 | 07:31 PM
  #105
I do like that cam spec. It isn't a traditional blower cam and should hold good power out of boost.
My fuel system is just a factory flex fuel pump with fuel injector clinic 1000s.
My next move on this would be to port the snout and get it machined to accept smaller pulleys (2.5 would be a good size I think). Anyone have a good lead?
Old May 12, 2020 | 09:51 AM
  #106
Jeebalow's Avatar
I have heard nothing but good things about his cams. I hope to get it all pit back together and fired up within a month or 2. I also have some other changes I'll be making to the truck since it's in a 95 C1500.
I wonder what the flow rating is on a factory flex fuel pump. ill have to do some searching.
you have a 10% OD crank pulley right? What RPM is that blower rated for?
Old May 12, 2020 | 02:04 PM
  #107
I am spinning it just above 19kRPM today, but just based on the LSA blower speed limits that exist out there you should be able to go all the way to ~25-26kRPM.
With a 2.45 upper, I expect I would maximize my net engine power at around 730HP@crank and would be at approximately 22.5kRPM. Spinning it any faster on my size engine would probably only hurt crank output.
Old May 6, 2021 | 06:32 PM
  #108
Just a small update. Conditions weren't as favorable as last time (headwind) and I still picked up time. Short track was worse because I couldn't hook with the new tires as well as the old (I just run a cooper evolution ht) but tune modifications were moving me the right direction.
Old Aug 10, 2021 | 11:01 AM
  #109
I've been doing a lot of my own tuning and have been wanting to get shift RPM up, but have been limited by the factory flex fuel pump even with voltage tweaks and large injectors. I can get to about 5k before the pressure falls and about 6200 to 6500 before it gets leaner than I am comfortable. So I took notes on someone else's 450 pump install and tackled the same setup over the past few weeknights. I haven't installed it yet, but hoping this gets me up to a 7 or 7200 rpm shift to further pick up e.t.
Old Aug 10, 2021 | 11:14 AM
  #110
arthursc2's Avatar
That looks great! Did you mod the module yourself?
