2001 Frame up build
Old Sep 12, 2008 | 09:44 PM
  #411
haha, thanks man!
Old Sep 12, 2008 | 09:49 PM
  #412
1FastBrick's Avatar
Custm2500's Rude Friend
Getting back to it this weekend???
Old Sep 12, 2008 | 11:12 PM
  #413
kbracing96's Avatar
Better hurry up and get it built, or your gona forget how to put it back together Looks nice
Old Sep 12, 2008 | 11:27 PM
  #414
Manbearpig's Avatar
Cant wait to see that BASTID done
Old Sep 13, 2008 | 03:53 AM
  #415
I wish I could finish it this weekend, once I pick up a t56 then I will be able to get it done, till then I'm kind of stuck.
Old Sep 18, 2008 | 07:48 PM
  #416
lsx10's Avatar
wow, I just finished reading all 42 pages.. damn man, you went above and beyond with this thing. if it were me I would have just stuck with the original frame you built. I'll be following this thing for the rest of the build.
Old Oct 12, 2008 | 11:34 PM
  #417
Wyttrash96's Avatar
I hate my cats
Find a 6 gear to row yet dude?
Old Oct 20, 2008 | 02:49 PM
  #418
Found ONE!!!! and here is the progress
Grabbed my 4.8 to use for mockup
Cut and drilled some plates to mount to the engine for the engine side of the mount
Started to cut the tubing for the frame side of the mounts, and notching it
Laid them out, trimmed where needed and tac'd them in place
All set and ready to go
Welded up the motor plates solid, ran the piece across to prevent movement in the spacing
I plan to gusset between the two plates and on the sides before I powdercoat them
Since everything was tac'd I yanked the motor with my new motor hoist, bout time I bought one, I was sick of borrowing tools, "ask to borrow once, that's fine, twice, you should think about buying one, three times don't even ask"
Welded the mounts up solid
Put the motor plates back on
  #419
Put the bushings back in
This is my temporary trans x-member set at the right height an all, just ran out of material for my permanent one, the motor sits so the tailshaft is at a downward slope of 3*
Bombed the 4.8 to look better in pics :crazy: and put it back in for the week
The motor was moved up slightly 1.5" and back about 1" I wanted to get it lower back couldn't do so without compromising too much. This should be fine though.
Old Oct 20, 2008 | 02:53 PM
  #420
gtosilverado's Avatar
looking very nice man !!! good work !!!
