2000 silverado rclb to rcsb drag truck low budget conversion
Old Jul 27, 2012 | 02:34 PM
  #371
ak2007r6's Avatar
so my 6l80e is really a 8l80e??
Old Jul 27, 2012 | 02:45 PM
  #372
mybigwarwagon's Avatar
Originally Posted by CAGRacing
All 7 gears and torque converter lockup.
Originally Posted by custm2500
If I am correct the 4L60E and 80 are actualy 6 speed transmitions. They have an intermitent gear ratio between 2-3 and 3-4. They aren't considered another gear for what ever reason. My tranny guy never explained it any more then that. If that is true then maybe he can lock it into those intermitent ratios if he so chooses?
Holy crap you two are smoking some good stuff.
Probably both voted for Obama too.
Old Jul 27, 2012 | 03:38 PM
  #373
CAGRacing's Avatar
7 gears, 7 states of the transmission valves
There's 3 valves that control the transmission
1-2
2-3
3-4 shuttle
There's 7 combinations used to control a 4L60e
Look at the transmission flow chart. There isn't any point in which 1 valve supplies pressure to 1 band. It's all combinations.
Old Jul 27, 2012 | 03:39 PM
  #374
nonnieselman's Avatar
See if you can get ahold to that transmission guy and get him to explain it..
Ive been in a few transmissions and i dont see how you can make 2 extra gear ratios when there are only a couple clutch packs and a band.....
Old Jul 27, 2012 | 03:40 PM
  #375
1-2
2-3
3-4 shuttle
So how do you split the combos and get 3 extra gear ratios?
Old Jul 27, 2012 | 03:45 PM
  #376
lglowe's Avatar
Must have stayed in a holiday inn express last night..........
Old Jul 27, 2012 | 03:52 PM
  #377
CAGRacing's Avatar
You don't have more gears
There's 4 forward
There's neutral
1 reverse
And park engages 2 simultaneously
Now look at how a transmission works. There's an inner that spins. Then engages another gear that's around that gear. Then engages another outside of it. An auto is planetary gears. There aren't 4 completely separate gears that it switches between. It "stacks" gears.
Old Jul 27, 2012 | 04:00 PM
  #378
SlickSierra's Avatar
Id let the metal recyclers buy it
Old Jul 27, 2012 | 04:17 PM
  #379
ak2007r6's Avatar
Good to see OP back.
Can we see a time slip of the 11.2 pass?
Can we see a print out of the truck weighing 2400 pounds?
Can we see a dyno print out of the motor making 400hp?
Can you please reply to my email I sent asking about your add on CL???
Thanks
Old Jul 27, 2012 | 04:35 PM
  #380
hahahah you literally meant P, R, N, D, 3, 2, and 1 all work.. think everybody took you the wrong way..
Now the only difference between P and N is P engages the Park Pawl.
